Results 1 to 3 of 3
Thread: 4th axis movement (and a few other gen ?s)
    Aug 2004
    hey everyone - new member here..
    I don't have a cnc machine yet, I'm waiting for the acumotion ppl to call back - but in the meantime, I figure I can learn to program the software.
    So, what g-codes are used to rotate the rotary table? I tried something G00 A5, but that doesn't seem to do anything. I haven't found any GOOD g-code references online, anyone have any references? Somethign that shows various ways to use certain g-codes...
    Also, does anyone know of places with canned cycles/programs that I can use to learn from
    wms
    wms is offline
    Moderator wms's Avatar
    Mar 2003
    Dear Corpse, (I hope that is not how you really are. )
    It would depend on what your rotary table and controller want to "see" to index the table. G00 A5. would move a Haas table 5 degrees.
    Do you have any manuals with your table? Or your controller?
    As for the G code thing do a search here and you should finds several posts. I remember one just the other day Started by a Kathy, that had some good links.
    Here is a link to that post. G-Code letters What are the definitions?
    Unfortunately ever controller can use different G codes. So again it would be depend on what you are using. Same thing with canned cycles.
    Aug 2004
    I don't have anything yet -as I mentioned, I'm planning on ordering the cnc when I get ahold of the Acumotion ppl (person).. The A axis *seems* to be supported http://www.acumotion.com/gcode.shtml but when I try it in their software, the display isn't updating, like it does with the x/y/z - so I figured I might be doing it wrong. I suppose I should just stick with learning x/y/z before I hit the rotational stuff - at least until I get the unit
  1. CNC Glossary
    By CNCadmin in forum CNCzone Club House
    Last Post: 03-09-2008, 04:08 PM
  2. Axis Movement
    By UKRobotics in forum General Metal Working Machines
    Last Post: 12-17-2004, 02:33 PM
  3. 5th even 6th axis? how does it work
    By ToMMY2ooo in forum General Metal Working Machines
    Last Post: 10-04-2004, 04:58 PM
  4. My Lathe project; might CNC it one day
    By Stevie in forum General Metal Working Machines
    Last Post: 06-21-2004, 09:27 PM
  5. 2.5-Axis vs 3-Axis
    By JamesBond in forum General Metal Working Machines
    Last Post: 07-26-2003, 08:09 PM
