Old 08-03-2004, 11:57 PM
starCNC is on a distinguished road
Will 63" long Rail sag without using shaft support?
I want to know if thomson SSU PBO 20 rails sag without using shaft support
Old 08-04-2004, 02:03 AM
the4thseal is on a distinguished road
looks like you have low profile supprts, i would use them. Nice rails
TC
Old 08-04-2004, 07:44 AM
jwatkins is on a distinguished road
You bet they will. Question is, how much? There's a formula for figuring it out which I don't remember, but the quickest thing would be to simulate the weight that will be riding on those bearings and measure the deflection. Also, since you've got the bearing style with an open side, it would be pretty easy to add some support along the length.
Old 08-04-2004, 08:34 AM
BigDaddyG is on a distinguished road
Yes they will! Not only will deflection be a problem, but the harmonics will come into play when you get the thing working, I assume your doing a router thing, when stuff gets spinning and cutting the harmonics will be a BIG problem. Plan on putting supports under the rail, preferably along the entire rail. Good Luck.
Glen
Old 08-04-2004, 09:16 AM
Bloy2004's Avatar
Fumbling Machinist
Bloy2004 is on a distinguished road
Did you snag these on ebay? Looks like they already have a support plane/strip. ....just got to mount!
Old 08-04-2004, 09:29 AM
I got them off ebay, they do come with shaft support. i was just wondering if it will be ok to not use them. Now i'm planning to sit them on top of 80/20 tslot
Ballscrew Basics Swede Linear and Rotary Motion 94 09-06-2011 07:23 PM
shaft support smarbaga Mechanical Calculations/Engineering Design 0 04-16-2005 09:58 PM
Wrong THK rail - Help! samualt DIY-CNC Router Table Machines 10 07-17-2004 02:26 PM
