Page 1 of 2 12 LastLast
Results 1 to 12 of 15
Thread: Ballscrew or Backlash Compensation?
    Jun 2004
    I am wanting to build a small router for doing pcb's etc and am trying to decide between ballscrews and backlash compensation. I have priced ballscrews locally to be just short of $1k aud for screws and nuts - this is prohibitively expensive. Is a square or acme thread with software compensation just as accurate? I am hoping to be accurate to +-0.1mm is this an achievable goal with square threads and software?
    Ben
    Nov 2003
    Acme screws with Delrin nuts works good. There are quite a few ideas floating around these pages for DIY antibacklash nuts.
    Nov 2003
    BTW, I would avoid software compensation if possible. I think it's better to get your hardware tight rather then trying to compensate in software.
    Apr 2004
    Jun 2004
    Hey, thanks for the help. I think I will use Delrin and a good quality ground acme leadscrew. The steppers I have are a good size already, and if it just means I will be going slower, then thats ok as I am not doing production or anything. At the moment all I see the router doing it PCB's, brass plates, and foam contours for either casting or making wings etc.
    I am actually planning on a cnc hotwire cutter also.
    Regards
    Nov 2003
    Hey, don't think using acme screw means it won't go fast! I swear by the 1/2" 10TPI 5 start screws I have on my machine (X and Y axis) I get 300IPM+
    On the Z axis I have 1/2" 10TPI 2 start screws and get about 120 IPM
    Oct 2003
    Sweden
    Quote Originally Posted by RXTurbo
    /.../ I am wanting to build a small router for doing pcb's etc and am trying to decide between ballscrews and backlash compensation. /.../ Is a square or acme thread with software compensation just as accurate? I am hoping to be accurate to +-0.1mm is this an achievable goal with square threads and software?
    The choice is not between ballscrews and backlash compensation. Ball screws will also have backlash if they aren't preloaded.
    If you want your machine to have a repeatability better than +-0.1 mm, you should be fine with precision ACME with tight or preloaded nuts.
    There's good and bad ACME, just as there's good and bad ball screws. Look at the specifications of the particular screw you are interested in to see if it's good enough.
    Make sure you can get the repeatability you are after without using software backlash compensation!
    Arvid
    Jun 2004
    Okay, I have found some good quality stainless V threaded rod and some delrin at good prices. I have attached a drawing of how I see preload being applied - can anyone say if this is a suitable method?
    I am thinking of using M6x1.0 rod which will give a resolution of 0.005mm per step.
    Thanks again for your help.
    Ben
    Attached Thumbnails Attached Thumbnails Ballscrew or Backlash Compensation?-backlash.bmp
    Mar 2003
    Shelby Twp, MI....USA
    You'd be better off using ACME or Trapezoidal (metric acme) instead of the V thread, if you can get it easily.
    Jun 2004
    Gerry, What happened to the image link that was originally posted? And why does the forum replace some web addresses with ***********'s?
    I was thinking of the V thread from an accuracy point of view - I can buy ground threaded rod and a tap to cut the delrin. To do this as an Acme thread I would have to cut the thread on both the lead and the nut. This would also mean having to grind tools to do the job - surely a V thread and tapped nut would be more accurate than a lathe cut thread?
    Site Owner CNCadmin's Avatar
    Mar 2003
    Please read this-
    http://www.cnczone.com/forums/faq.ph...censor_explain
    Their are certain websites that I don't allow linking to for personal reasons, sorry for the trouble.
    Thank You,
    Paul G
    Site Owner-Webmaster-
    Administrator
    www.rfqwork.com
    www.cnczone.com
    www.welderzone.com
    Oct 2003
    Sweden
    *snip*I was thinking of the V thread from an accuracy point of view - I can buy ground threaded rod and a tap to cut the delrin. To do this as an Acme thread I would have to cut the thread on both the lead and the nut. This would also mean having to grind tools to do the job - surely a V thread and tapped nut would be more accurate than a lathe cut thread?
    Why can't you buy ACME/trapezoidal screws?
    Where is ground V-threaded rod used? I thought V-thread is intended for fastening and then I can't see what use it would be to (precision) grind it?
    BTW, V-thread is a lot less efficient at transfering motion than trapezoidal. That makes sense if you think about that it is meant for fastening things (preventing motion).
    Arvid
  • Page 1 of 2 12 LastLast
    1. Ballscrew Basics
      By Swede in forum Linear and Rotary Motion
      Last Post: 04-16-2012, 09:09 PM
    2. Ballscrew pitch error compensation
      By Scott_bob in forum General Metal Working Machines
      Last Post: 06-21-2011, 08:24 AM
    3. Backlash Compensation
      By utengineer04 in forum General Metalwork Discussion
      Last Post: 04-26-2005, 12:42 PM
    4. Backlash comp: does other axis pause during?
      By lesd in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 11-30-2004, 02:05 PM
