Old 03-16-2008, 07:29 PM
Ed Williams is on a distinguished road
Mill Bit 6061 aluminum
I have been using a tin coated 1/8" 2 flute bit from Enco. Is there anything better to mill with for 6061 aluminum.
Thanks Ed
Old 03-16-2008, 10:06 PM
Mitsui Seiki's Avatar
Mitsui Seiki is on a distinguished road
It depends on what kind of maching you are talking about.
Stefan Vendin
Old 03-16-2008, 10:31 PM
larry53 is on a distinguished road
endmill
You might want to try a endmill that is better when cutting aluminum. There are endmills that have a higher helix angle that are made to cut aluminum.
Old 03-16-2008, 10:45 PM
cnczoner is on a distinguished road
I've experimented with various endmills for 6061-T6 and I like the plain HSS ones from Shars. I know there's better, but this is bang for the buck. Also, I try to use larger endmills where possible, and I can usually do most things with a 3/8" or 1/2" endmill. I used to think that I'm cutting more metal so it would be more inefficient, but because they're stronger, I can run faster and I get a cleaner cut. I plan to try some 3/4" endmills next. BTW, their 1/2" roughers are also great bang for the buck, but not center-cutting.
Cheers,
-Neil.
Tig VS Mig for aluminum 6061-T6 square tubes PJet Welding, Brazing, Soldering, Sealing 19 03-20-2008 12:52 AM
Springback on 6061 Aluminum Tabs PinMan Bending, Forging,Extrusion... 1 02-25-2008 12:31 PM
machining 6061 aluminum conlimon Benchtop Machines 16 09-19-2007 07:20 PM
Help - Cutting Aluminum 6061 dfranks DIY-CNC Router Table Machines 50 11-18-2005 03:32 PM
Turning Aluminum 6061-T6 Machine1 Hard and High Speed Machining 3 09-11-2003 12:04 PM
