Old 03-16-2008, 03:59 PM
cnczoner is on a distinguished road
CNC Mill --> CNC Lathe.
Add a R-8 4" chuck (Ebay), a 3"x3"x3" angle plate (Enco), and a Lathe quick-change toolpost (stolen from my 7x10), and I now have an instant CNC lathe. No thru-hole, but that is not an issue for my purposes.
Once I prove the concept and useability, I think I'll get a small spare micro-mill table from LMS and make a gang-tool plate out of it.
Cheers,
-Neil.
Old 03-17-2008, 08:29 PM
allchevy is on a distinguished road
looks a little dangerous
Old 03-18-2008, 06:23 PM
Why would it be any more dangerous that a lathe of the same capacities? (Ignore the long-ish tube btw, as it's the only round material I had for testing at the time).
Cheers,
-Neil.
Old 03-18-2008, 07:58 PM
looks cool but tool center line is very important any backlash or movement in the bed of the mill will change center line . everyone has thrown something out of a lathe chuck ..i think if it happens it might damage the spindle ..whats the max dia of fly cutter you can use on your mill ?
Using a CNC mill as a lathe Vern Smith Haas Mills 119 08-08-2008 06:38 PM
CNC Lathe on a mill - what do I need? digits Benchtop Machines 35 06-02-2007 06:12 PM
lathe or mill niimush Mini Lathe 5 01-19-2007 04:14 PM
Mill and lathe tnc General Metal Working Machines 2 11-19-2006 11:10 AM
Am I a mill or a lathe. Art Ransom Mach Mill 1 10-03-2006 08:08 AM
