Old 07-31-2004, 03:03 AM
starCNC is on a distinguished road
Any recommended Timing belt and pulley?
Looking for timing belt and pulleys for travel 63" and 53" What Ratio to use? My motor shaft is 1/4".
Old 07-31-2004, 08:41 AM
ger21's Avatar
Are you looking to do something like this?
http://www.axxustech.com/Axxus4x8/axxus_4x8.htm
Old 07-31-2004, 10:24 AM
I'm not trying to use belt to move the axis. i just want to attach the pulley to the end of ballscrew. Where can i find those pulleys on the router?
Old 07-31-2004, 12:59 PM
Chagrin is on a distinguished road
You need to post details on your motor (stepper/servo and torque) and ballscrew (TPI) before anyone can suggest a good ratio for the pulleys.
Old 07-31-2004, 07:08 PM
owhite is on a distinguished road
Stock Drive Products:
http://www.sdp-si.com/
They have piles of cad drawings, pdf files specifying pulleys and belts, and a straight-forward ordering system. Once I picked out the pulleys and got the diameters from the sdp site I had to make an educated guess about the length of the belts. For my application I put the geometry of the motors, pulleys and ballscrews in a CAD drawing and figured out the number of teeth required for the correct length belt and ordered everything up.
Old 07-31-2004, 07:09 PM
Right now i have powermax 2 p21 112oz/in, i'll be upgrading it to 785 oz in 2.5A 3 ohms stepper motor from seanet.com. using 5/8" .2pitch ballscrew.
Old 07-31-2004, 08:09 PM
Cold Fusion is on a distinguished road
If you have the money I suggest going with the Gates Powergrip style. It can handle much more power then similar sized belts and has vitually no backlash. My router uses them and I couldn't be happier.
Proud owner of a Series II Bridgeport.
Old 07-31-2004, 11:46 PM
cold Fusion,
What ratio are you using?
Old 07-31-2004, 11:49 PM
1:1.5 on both my 10mm and 20mm leadscrews.
Old 08-01-2004, 12:25 AM
Do you have pulley A and B part numbers?
BTW: i liked your router, do you have more video on it.
  #11   Ban this user!
Old 08-01-2004, 12:29 AM
I do but they won't do you any good since the inner diameters are different then your's. Just browse Sterling in the metric section for metal timing gears and belts matching your specs. I used a 24t on the motor and a 36t on my ball screw.
Soon I'll cut together a nice video showing everything from programming to machining.
What is a timing belt and pulley ? ynneb FAQ of CNC Machine building 2 02-18-2011 07:38 AM
New CNC Machine - Building Stage! JavaDog CNC Wood Router Project Log 218 08-09-2007 10:56 PM
Boss z-axis belt slipping jderou Bridgeport and Hardinge Mills 13 06-01-2005 02:08 PM
Stepper Math questions... Aegeon Mechanical Calculations/Engineering Design 2 04-28-2005 11:22 AM
Belt size - help needed Moondog DIY-CNC Router Table Machines 3 08-09-2004 07:56 PM
