Page 1 of 2 12 LastLast
Results 1 to 12 of 23
Thread: CNC Punch press plans
    Registered metalworkz's Avatar
    Oct 2006
    Modesto, CA U.S.A.
    Hello,
    I have not seen any mention of plans to build a CNC punch press here or a forum here dedicated to CNC punching or Amada turrets in particular.
    I have been planning on making a CNC punch with around a 24" x 36" travel for some time with about a 5 ton punching capacity. I also wanted to make a CNC router table with a similar travel and thought maybe I could do a combination tool with either an interchangeable work head or tool heads at opposing ends. If anyone has seen a thread for a CNC punch press build I would appreciate if you could point me in the right direction to check out the thread. Thanks for any information that can be provided.
    Regards,
    Regards,
    Wes
    Oct 2006
    Modesto, CA U.S.A.
    I'm thinking I may end up doing something closer to the Amada SP30 punch press for a shop CNC punch(single station). It would basically be a small capacity punch with an X and Y axis attached and would allow a much more stable punching station. The part is just held up against the X and Y gauge blocks and then relocated each time the axis move to a new coordinate. The SP30 comes with a 3 station tool holder but even with a single station tool holder it is quick to make tool changes.
    Apparently there are not too many CNC punch operators that frequent the CNCZone as there are no replies and probably as little interest in this type of machine. For sheet metal a punch is much faster than a laser and machining and is optimum for production.
    Maybe that is why there is not even a forum dedicated to CNC punch presses.
    Regards,
    Regards,
    Wes
    Registered dang's Avatar
    Jul 2004
    CNC Punch Press
    No plans, but I found these. They were taken at the NEMES '08 show. I'm also interested in a machine like this. I'd sure like to see the plans for these machines.
    Attached Thumbnails Attached Thumbnails CNC Punch press plans-cnc_punch_press.jpg   CNC Punch press plans-cnc_punch_press2.jpg
    Oct 2006
    Modesto, CA U.S.A.
    The Roper Whitney CNC conversion is close to what I am thinking of except I would make it with all the X axis travel to the left side of the ram. That way it can be positioned so as to leave the front working area clear of moving parts. It makes for easier access to the punching area with no obstuctions. I would like to have a single stroke hydraulic or mechanical ram actuated with a foot pedal also. Even an old kickpress would be a good foundation for a conversion. The frame would be sturdy to attach the axis to and then you would be able to hold the part with your hands and kick the pedal to punch when the axis are at the location..
    I have a CNC router/mill of about 2' x 3' in the works now but the CNC punch press definitely needs to be addressed after that. Thanks for posting the pictures! Keep me informed to your progress if you are going to make a CNC punch. I will post any progress I have with the plans for my CNC punch as they are available. I currently operate the Amada EMK 3610 NT CNC punch(pictured in my avatar) which is completely servo driven. It's an awesome machine and I know my CNC punch will be no where close to it but it will be an awesome tool to have in the shop.
    Regards,
    Wes
    Jul 2005
    Hey Metalworkz and Dang,
    Are you guys still around! I remember seeing a machine similar to the second picture that dang posted for sale a long time ago for around $1500US. I figure it should be fairly easy to build a machine like that from a mechanical view point but finding the software to output the correct axis positions for punching might be a bit of a challenge.
    I'm up to my eyeballs in alligators for the moment, but might start a new build thread this winter if you guys are interested.
    Rob D.
    Oct 2006
    Modesto, CA U.S.A.
    Hi Rob,
    I am interested, and I plan on building something generally similar to the Amada Sp-30 hydraulic punch. I have not done any drawings other than some pencil sketches yet but I have a lot of experience with sheetmetal and punching in particular and would like to build something for my shop. Keep me informed when you get around to building yours.
    Best regards,
    Regards,
    Wes
    Jul 2004
    I'd be really interested in that build thread as well.
    There's plenty of software out there to do the CAD/CAM part, some of it is quite expensive. I think that with the usefulness that this type of machine would present to me, that I'd be willing to buy the cheaper versions of the wares.
    Alligators huh? You in Fla? Where?
    Moderator Switcher's Avatar
    Apr 2005
    mydxf.blogspot.com
    Free DXF Files - myDXF.blogspot.com
    Jul 2005
    Thanks Switcher!
    That's the one ... except with inflation!
    Wes & Dang,
    I was thinking of using a 1 or 2 ton OBI type punch press and replace the relay with a 5 volt for use with a breakout board, probably weld c-channel to the press frame for alignment then sever the back of the press throat to get 48 inches of total stroke - I've got a couple of 4 foot 1mm ball screws I was going to use when I get a round to it (or a Squaretoit for that matter).
    Dang,
    I wish I was in Florida .. I'm up here on the shores of Lake Ontario in the Great White North!
    Oct 2006
    Modesto, CA U.S.A.
    Wow, you're aiming for a lot of travel: 48" x 48"? I would be able to get by fine with say
    X36" & Y15", but I'm thinking of shooting for X36" Y24" for a CNC punch in my garage shop. How do you plan on bridging the gap after severing the back of the press?
    Best regards,
    Regards,
    Wes
    Jul 2005
    I was thinking I might build a 4x8 double tiered structure with 2 1/2 or 3 inch sq tube, place the punch in the front center of the structure, then use pre-stressed c-channel to bolt through the top and bottom of the yoke before severing the back of the throat.
    I was hoping for a half sheet capability in aluminum between.092 to .125 (6061 or 5052), but I may be forced to scale down to between 24 and 36 inches on one of the axis because the envelope doubles for a full stroke of movement.
    It's a big footprint for my little shop/garage and I could get a full sheet capability if I went to a plasma rig (even with one of the cheap chinese 30amp units) ... but plasma's alot dirtier for home use ... and it simply isn't the same!
    Rob
    Oct 2006
    Modesto, CA U.S.A.
    Hello guys,
    Are any of you still around and thinking about the CNC punch press idea? I just finished a small CNC bridge style router and am thinking of doing a small CNC punch press build for my garage shop. Anyone take their ideas further and get their build started or done?? I'm still thinking a kick-press would be a good foundation for a CNC conversion for punching. Foot activated so the part can be held with both hands as the X and Y gauges move to position and then the pedal is kicked to punch through the material. I hope there are still some people interested or pursuing this?
    Regards,
    Regards,
    Wes
  • Page 1 of 2 12 LastLast
    1. CNC punch press software
      By Uglybob in forum General CAM Discussion
      Last Post: 08-20-2011, 11:47 AM
    2. CNC benchtop punch-press
      By 307startup in forum CNCzone Club House
      Last Post: 12-06-2010, 09:07 AM
    3. Strippit #fc-750 Cnc Punch Press
      By cskedk in forum General Metal Working Machines
      Last Post: 03-31-2010, 07:49 AM
    4. Punch?? or What??
      By ShayArnett in forum General Metalwork Discussion
      Last Post: 03-19-2010, 10:28 PM
    5. NorthStar Press Brake For 20 Ton Shop Press anyone ever use one?
      By dsmdude in forum Bending, Forging,Extrusion...
      Last Post: 04-13-2007, 05:01 PM
