Old 03-12-2008, 10:13 AM
KJ45 is on a distinguished road
Tool Changer picks up wrong Tool?
We are using Chevalier CNC Mill with Fanuc control.
Up until today there has never been any issue with the Tool Changer, but today it started picking up the wrong tool.
When it is programmed to pick up T2 it picks up T1. This happens with any tool number we program.
I have never seen this happen, but am hoping the solution is relatively simple.
I would appreciate any help.
Old 03-12-2008, 05:25 PM
fuzzyracing1967 is on a distinguished road
Just wondered,do you mean it allways picks up tool 1,or it will pick up the tool 1 spot lower then programed (t5 when t6 is called) ?
Old 03-12-2008, 05:44 PM
GEM GEM is offline
GEM is on a distinguished road
Tools
Similar problem on a leadwell with OM control, would occasionly start selecting tools one pot out. Our machine used a proximity of some type for counting. Every so often, whilst machining, a piece of swarf would drop across the switch face, and it would increment by one, or sometimes more, hence putting the tool changer out. Cleaning all swarf from the surrounding area cured the problem. Seemed odd to me that the program did not just look at this switch whilst rotating, but would increment even if no rotation commanded. Bad program writing, programmers should always run the "what if" scenarios
Old 03-12-2008, 05:58 PM
We have an old comet vmc that this happens too from time to time.The tool magazine is rotated by a sproket and cam arm,and if for any reason it is interupted it can get out of wack.There's two ways to fix it,ether change the peramiters or fake it out by hitting e-stop in the middle of tool change.
Old 03-13-2008, 06:10 AM
It is always 1 spot lower, it will pick up T5 when T6 is called, T16 when T1 is called, etc.
Old 03-13-2008, 06:12 AM
Thanks for the answers - we will try these solutions and respond back later.
Old 03-13-2008, 06:51 AM
SORCHEROR is on a distinguished road
clean the tool changer and the proximity switches and reboot the machine,should fix it
or maybe a bad switch
Tags
cnc mill, tool changer
tool changer axkiker DIY-CNC Router Table Machines 13 03-09-2008 07:28 PM
Tool Changer Paul Petersen Fadal 2 11-14-2007 11:40 AM
Tool Offsets - What's wrong with this Gear? edo G-Code Programing 2 12-27-2006 10:40 PM
Tool Changer Moondog Mach Software (ArtSoft software) 4 05-21-2006 02:34 PM
Tool Changer - How? creative_mind CNCzone Club House 17 08-30-2003 10:01 PM
