Old 03-12-2008, 02:07 AM
chopper14 is on a distinguished road
what and how to make press brake vee block
Hi all
I am wanting help in making a press brake vee block.
The pess brake is a 50 ton.
I have milling machine so meching is no problem.
what grade of steel is the best and at the same time keeping the cost down
Old 03-12-2008, 06:13 AM
bigtoad170 is on a distinguished road
How long are wanting to make it ? I've worked in prototype shops and just have mild steel hardened for short runs if your just bending light sheet metal it will probably get you through maybe 100 -200 parts before it starts to mushroom. Sometimes if you go to a machinery bone yard you can see v blocks on old machinery and you can make an offer on them. We also used a steel called fx extra that didn't need to be hardened and that stuff was amazing when we used in the presses it would even keep a shear edge for hundreds of hits I wasn't in purchasing so I don't know how expensive it was but a real time saver just machine it and go. If your looking for a block thats only 4 to 6 inches long you can pick them up fairly cheap and save you a lot of time.
Feedback on press brake dnorton77 General Metal Working Machines 9 07-21-2009 07:55 AM
NorthStar Press Brake For 20 Ton Shop Press anyone ever use one? dsmdude Bending, Forging,Extrusion... 6 04-13-2007 04:01 PM
I need someone with a Press Brake murphy625 Employment Opportunity 0 01-25-2006 04:11 PM
