Old 03-10-2008, 05:51 PM
bob1112 is on a distinguished road
Way lube issue on Mori lathe
I notice the other day that when I manually fire my way lube, it spikes the needle and then immediately drops. Just curious if ALL machines should hold pressure in the way lube system or not?? I know our Haas holds for 10-20min but I can see on the mori, like 20 lines just on the Z axis alone. Just thought if there was enough lines, it might drop fast. Not sure.
The machine has set idle for a few months and I did notice surface rust on the ways. I was able to easily remove it with a red scotchbrite rather easy. These two occurrences have me wondering if I have a lube issue or not. Ideas? How do you find a leak? Is there a common place in a two axis slant bed?
Old 03-10-2008, 06:19 PM
BlueChip's Avatar
BlueChip is on a distinguished road
Way Lube Notes
Not really sure about your specific machine ... but here is a link with some useful info :
http://www.kentechinc.com/tip1.html
Hope it helps in some way.
Old 03-12-2008, 12:38 AM
I did read that artical but it only covers the piston type luber and mine is electronic fire and not real sure what the mechanics are. I was just wondering if it is a simple pump and needs to pump longer. When it energizes, it spikes the needle immediately. Anyone familiar with this type of luber? Guess it might help to have a make and model on that huh?
B
Lathe program/alarm issue kperk12345 Okuma 6 10-11-2007 01:57 AM
Issue with my Cummins Lathe...HELP!! azcarbum Mini Lathe 6 03-03-2007 08:58 AM
wht lube oil to use on CNC lathe..? bala_51083 General CNC (Mill and Lathe) Control Software (NC) 2 09-29-2006 06:10 PM
Help!! Surfcam Issue-Mori Seiki Control MachineManOK General CNC (Mill and Lathe) Control Software (NC) 0 03-02-2006 11:52 PM
My first lathe! What lube to use? gdl357 Mini Lathe 2 08-18-2004 11:06 PM
