Old 03-10-2008, 12:54 PM
CuttersCov is on a distinguished road
Question Manual machine vs. CNC
I'm looking to buy a milling machine and lathe soon. I've been considering converting them to CNC, but wonder is there a disadvantage to them being CNC instead of manual?
It would seem that one benefit is a very simple part, such as milling a slot in a piece of square stock.
Is it possible to make a machine CNC AND keep it manual driven, such as removable motors.
-Matt
CNC Blog:http://cutterscove.blogspot.com/
Old 03-10-2008, 01:04 PM
Is this to start a business or just for a hobby?
If it is business, or even a hobby that you hope will develop into a business go for CNC. Everything that is possible on a manual machine is possible on a CNC, but not the other way around.
I suppose I should qualify that...on a CNC you cannot swivel the head around to work on the end of long stock clamped hanging down beside the table like you can on some knee mills, and there may be a few other minor things.
When you are making one part sometimes the manual machine will be faster, three parts and it is almost certain to be faster on the CNC. And on a CNC it is trivial to radius corners on an outside profile, thread mill on a boss sticking out from a part, engrave part and serial numbers, and many other operations that are either very tedious or impossible on a manual machine.
Old 03-11-2008, 05:11 AM
mc-motorsports's Avatar
mc-motorsports is on a distinguished road
I have a bridgeport with a retrofit that had one handle on the X and the handle on the Y, you could still use it as a full manual machine just by slipping the belt off the quill motor. The handles are off now, it's just so much easier to jog around with the table. The one nice feature is being able to remove the belt and use the quill in manual mode. Especially for power tapping since I have no control over the spindle for tapping, ect. I have another machine that uses the Elrod Quill Retrofit which you run the quill all the way down, use a 1/4" allen key and then you have manual control over the quill again, very useful. Other than that, I don't turn handles anymore.
good base manual milling machine for future retrofit hansw3 Bridgeport and Hardinge Mills 1 11-12-2007 06:21 AM
Need machine manual bherr Bridgeport and Hardinge Mills 1 11-22-2006 01:56 PM
Looking for a Machine Manual Randi Eldridge General Metalwork Discussion 2 06-16-2006 06:55 AM
I need a mori seiki machine manual imwllc General Metal Working Machines 2 09-08-2005 06:50 AM
manual machine shop MBG General Metalwork Discussion 20 08-17-2005 02:39 PM
