Old 07-27-2004, 12:40 PM
replicapro is on a distinguished road
Need help with math
a 360 turn of the hand wheel on my rotary table is 2.25 degrees of rotation of the table.
how much of a turn of the hand wheel = 1 degree of table rotation
Old 07-27-2004, 12:52 PM
DR-Motion's Avatar
DR-Motion is on a distinguished road
360 degrees rotation for handwheel = 2.25 degrees rotation for table
360 degrees / 2.25 = 160 degees
So 160 degrees rotation for handwheel = 1 degree rotation for table
embrace enthusiasm to accomplish the task
Gary Davies... www.durhamrobotics.com
Old 07-27-2004, 12:54 PM
*Registered*
metlmunchr is on a distinguished road
160 at the handwheel. Odd number though. Most rotary tables are 90:1.
Old 07-27-2004, 05:48 PM
IJ. IJ. is offline
Gold Member
IJ. is on a distinguished road
The other common ratio is 40:1.
Old 07-27-2004, 07:15 PM
Gold Member
imserv is on a distinguished road
Sherline's 4 inch tables are 72:1. Probably the most popular table ever.
Fred Smith - IMService
http://www.cadcamcadcam.com
Old 07-27-2004, 07:49 PM
Thats the number.
Turns into 425 steps in mach2
Old 07-27-2004, 08:01 PM
HuFlungDung's Avatar
Moderator
Yes, that 160 turn table would definitely not be classed as a user friendly rotary table for manual use!
Old 07-27-2004, 10:08 PM
*Registered*
Hu, everyone knows true "user friendly" dividing devices have motors attached to them. Motors help prevent so much of our blood from draining out thru our knuckles
units per inch math gearcut Mechanical Calculations/Engineering Design 4 05-29-2005 02:02 PM
Need some math help... kanankeban Mechanical Calculations/Engineering Design 18 04-03-2005 04:27 AM
math needed to build a cnc trubleshtr Mechanical Calculations/Engineering Design 1 03-16-2005 02:20 PM
Motor math...am I doing this right? WoodSnarfer Servo Motors and Drives 6 11-22-2004 07:13 AM
Timing Belts Math...Help! kanankeban DIY-CNC Router Table Machines 3 11-01-2004 10:19 PM
