Old 07-27-2004, 10:10 AM
kad2kam is on a distinguished road
How to hold small workpiece?
I have to mill few hundred of small blocks out of ABS sheet using 2D prog. Part is fairly simple and size is about 6mm cube having little corner radius. I'm trying to machine multi-pieces right thru out of a large sheet but problem is part moves and gets damaged at the end of the cut because no clamping left. Could someone advise the best strategy to machine without damaging the parts. Thanks in advance.
Kevin
Old 07-27-2004, 10:19 AM
Chombie is on a distinguished road
tabbing
Try using tabs, rout thru in some ares and not others and clean them up by hand. make tabs as thin as you can and you may be able to snap them off clean
Old 07-27-2004, 11:41 AM
I thought so but visual appearnace on the part surface is very important and part itself is so small that not much left for routing once I leave some tabs on.
Old 07-27-2004, 12:07 PM
tabs
How about 2 passes do tabs on the first pass, than cut tabs on the second pass. and also you might try contact cement. Are you using a down shear cutter I find that helps hold parts in place
Old 07-27-2004, 12:49 PM
*Registered*
metlmunchr is on a distinguished road
Heres a way I've done some thin sheet aluminum parts in the past. mill the profile, leaving the entire bottom of the slot intact but just a few thousandths thick. then drop down thru the part and cut it free with the exception of a small tab midway on each side. When you remove the sheet, you can turn it over and cut the parts free of the tabs with an exacto knife. Having the tabs NOT at corners makes this fairly easy.
Old 07-27-2004, 02:47 PM
buscht's Avatar
buscht is on a distinguished road
Some more options:
1. Leave about .002 material and run the blank through a sander (Performax drum sander) to seperate the parts from the blank.
2. Use carpet tape to hold down the sheet, cut normally, then pull the parts off of the carpet tape.
T
Old 07-28-2004, 03:28 AM
Klox's Avatar
Gold Member
Klox is on a distinguished road
I have seen it done like Metlmuncher says, it works! Otherwise it can be stacked and cut with a wire-edm.
Klox
*** KloX ***
I'm lazy, I'm only "sparking" when the EDM is running....
Old 07-28-2004, 02:02 PM
Graham S is on a distinguished road
I like buscht's 1st suggestion. You could do that in a mill, possibly adding extra clamping in the form of wax so the parts don't fly off.
Klox, edm ABS? That's a new trick
Old 07-28-2004, 02:20 PM
cadcam's Avatar
Community Director
cadcam is on a distinguished road
I like buscht's #2 suggestion. I have done this dons of times.
use 3m doulbe sided tape.
Use to do this for samll inserts for wax investment molds.
Cadcam
Mastercam Instructor , Programming Consultant and ME (Manufacturing Eng)
Old 07-28-2004, 07:50 PM
turmite is on a distinguished road
Klox
Klox can you edm plastic? I am probably showing my ignorance here but I have plenty of it to go around. I though ABS was a type of plastic and if it isn't be gentle when you tell me.
Mike
No greater love can a man have than this, that he give his life for a friend.
Old 07-29-2004, 02:08 AM
Klox's Avatar
Gold Member
Hey guys, sorry i read this thread while wearing my welding helmet! LOL! No you can't edm plastic!
My humble apologies........
Klox
*** KloX ***
Vacuum Hold down for wood. HomeCNC DIY-CNC Router Table Machines 46 07-24-2007 12:16 AM
How to Run a Large Stepper On A Small Board without frying Sanghera General Electronics Discussion 8 04-27-2004 06:39 PM
How does a servo hold its position? ynneb General Electronics Discussion 1 03-08-2004 10:10 AM
How do you hold stuff down? samualt DIY-CNC Router Table Machines 9 11-14-2003 12:24 PM
