Old 03-06-2008, 04:45 PM
cxixer is on a distinguished road
Sheet metal router bit
Say you want to cut 24ga galvanized steel on your CNC Router... What router bit would you use?
I have quite a few pieces to cut and a CNC router and a pair of tin snips... decisions decisions.
http://www.homebrewedtechjunkie.com - My techie projects, including a cnc build.
Old 03-06-2008, 09:39 PM
bobgerman is on a distinguished road
24 gage is pretty thin stuff. You might want to consider sandwiching it between some (sacrificial) plywood to hold it first. Use some double sided tape to keep it from sliding around (use sparingly and only on one side, the bottom side, otherwise you'll have some difficulty getting it apart). Instead of using a router bit I would use a carbide end mill. Not knowing the size of the part but lets say it's 6x6 inches sandwiched between two pieces of 1/4" plywood and your part has no inside radii smaller then 1/16" then a 1/8" diameter 4 flute carbide end mill will cut smoothly though both the sheet metal and the plywood at 15,000 RPM and a feed rate of about 8 inches per minute. You won't need to (nor want to) cut through the bottom piece of plywood.
Old 03-07-2008, 12:12 AM
That makes sense. Where do you get end mills as opposed to router bits? I'm a woodworking person, a metal working rookie.
Old 03-07-2008, 09:17 AM
I'm supplied by (www.use-enco.com) (best prices) or (www.McMaster.com) if your in more of a hurry. (www.mscdirect.com) is another equally as good as the others...Enco is just a little closer to me is all.
Sheet Metal Patterns phatfred8 Solidworks 15 05-21-2009 02:34 PM
Sheet Metal Countersinks kchritz CNC Tooling 1 10-24-2007 10:17 PM
Bit recommendation for sheet metal adda General Metal Working Machines 0 01-26-2007 01:50 PM
Tog Gun Construction From Sheet Metal username132 Europe Club House 0 01-15-2007 07:11 AM
cheap sheet metal MBG General Metalwork Discussion 1 03-04-2005 12:35 PM
