Old 02-27-2008, 09:34 AM
ligito is on a distinguished road
Bending
I would like to bend some clamps, similar to a 2 hole conduit clamp-3/4 id, from 1/8 x 1, or steel flat bar.
If I would do this with a Di-Acro, which bender would be able to accomodate 1/2 and larger id's?
Would a model 2 be too big?
I may use up to 2 in wide, for future projects
Old 02-28-2008, 03:31 AM
MetalBlade is on a distinguished road
Here is my advice, invest in a Oxy-acetylene set. I'm sure you can find it all with some small tanks for under $500 if you look around. Then you can bend all the steal you want and weld it too.
Old 02-28-2008, 01:00 PM
I have oxy/acet, wire feed and arc welder, as well as a 12 ton press.
I'd just like to find a cool way to bend brackets etc., using a bender, or the press.
Maybe someone could tell me how to make dies for the press.
In need of Mandrel Bending Twil759 Employment Opportunity 1 01-14-2008 03:26 PM
RFQ: Tubing bending Msport Employment Opportunity 2 01-19-2007 10:27 PM
bending CNC amir General Metal Working Machines 0 11-11-2006 02:07 AM
Bending wakeboard Bending, Forging,Extrusion... 7 01-18-2004 05:58 PM
Bending info Klox Bending, Forging,Extrusion... 5 05-13-2003 10:00 AM
