Old 02-25-2008, 09:17 AM
LuthierX is on a distinguished road
Talking 3 projects of CNC Router 3Axis, 4 Axis and 5 Axis
ID:	54153   Click image for larger version
ID:	54154   Click image for larger version
Old 02-27-2008, 10:39 PM
Talking
proress
ID:	54325   Click image for larger version
ID:	54326   Click image for larger version
Old 02-27-2008, 10:41 PM
Cool
progress
ID:	54328   Click image for larger version
ID:	54329   Click image for larger version
ID:	54331   Click image for larger version
Old 02-28-2008, 04:27 AM
High Seas's Avatar
Gold Member
High Seas is on a distinguished road
I do like the "Bridge Approach" (dual rails straddling the z axis) on your Y axis (its a favorite of mine too). If I could suggest:
consider rotating the z axis 90 degrees (about the z- vertical) - you might have an easier time changing bits in it.
That assumes you'll have access to the table along the X axis - which is most common. Any way you look at it - you'll be giving up working footprint - but make changing bits a bit easier.
Jim
Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
Old 02-28-2008, 07:08 AM
Khalid's Avatar
Khalid is on a distinguished road
good drawing...can u share ur design
Old 02-28-2008, 11:17 AM
I used studio max 8 3ds
Old 02-28-2008, 11:29 AM
Jim
Excellent suggestion, but as I make that?
Old 02-28-2008, 12:36 PM
JulioHB is on a distinguished road
LuthierX,
you are a crazy guy!
Manda bala garoto!!
Old 02-28-2008, 04:36 PM
High Seas's Avatar
Gold Member
LuthierX
Kinda like this:
http://www.cnczone.com/gallery/showp...00/ppuser/1938
Best of luck!
Jim
Old 02-28-2008, 06:35 PM
Smile
LuthierX
Kinda like this:
Best of luck!
Jim
is this?
Old 07-06-2008, 04:24 PM
High Seas's Avatar
Gold Member
Sorry for a very late response - but yes! Nice dagream too. You can see readily how your layout will prevent torsion (bending) as a result of the router/spindle weight being asymetricly mounted on the Y axis. You do have to make sure the Y axis members are rigid enough to prevent bending in the Z axis though.
Good Luck., and
Jim
  #12   Ban this user!
Old 07-06-2008, 08:26 PM
Khalid's Avatar
I am also a experience work on 3D studio max.. I learn it when we have 3d max ver 4 and now its ver9
3 projects of CNC Router 3Axis, 4 Axis and 5 Axis LuthierX General Metal Working Machines 0 02-25-2008 09:12 AM
DIY 3axis router milling machine pinemartin CNC Wood Router Project Log 18 05-23-2007 12:50 PM
4th axis on my router ronnieman CNC Wood Router Project Log 10 03-18-2007 06:35 PM
New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter the__extreme CNC Wood Router Project Log 3 02-26-2007 02:58 PM
Projects For 3-axis Mini-mill moose CNCzone Club House 0 03-24-2004 11:57 AM
