Old 02-22-2008, 03:21 PM
rkremser is on a distinguished road
Need suggestions for desktop drill Press
Hello, I am looking for recommendations for a desktop drill press around $100. I've looked into some options from harbor freight but wasn't sure if that should be considered as well as looked into a ryobi Drill press from home depot. What should be considered when purchasing. The drill won't see any heavy work, i'm thinking primarily thin steel, varying aluminum, and a variety of woods and plastics. So a whole range of materials and drill stroke doesn't have to be much over 2", nicer of course to have more but no real need right now. Chuck size I am open to, it seems everything has 1/2" and up. As for the number of speeds what should i be looking for? I feel like 5 would be enough 500-3000 but need input here too.
Old 02-22-2008, 08:58 PM
WolfmanJack13 is on a distinguished road
Try to find something that has low end speeds. 500 is still pretty fast for bigger bits, hole saws and for some metals.
Old 02-22-2008, 09:09 PM
High Seas's Avatar
Gold Member
High Seas is on a distinguished road
Suppose a dremel is too light for your purpose? It has variable speeds and they even have a mini drill press setup.
BTW if you need variable speeds -- Harbor Freight has a "router speed controller" on sale now for $9.99!
Jim
Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
Old 02-23-2008, 10:56 AM
Has anyone had any experience with any of the harbor freight drill presses, Or is it worth a 30 doller increase to get a ryobi branded one.
As for the speeds, I will most likely be looking into the option of the router speed controller but that can be added after if i do need to go below the 500 rpm minimum of both drill presses. I am leaning towards the Ryobi branded one as it has the same features and seems more solid. The Central Machinery one just doesn't seem to be of the same quality
Looking for Desktop CNC Drill in Malaysia/Asia Joe_Hann Benchtop Machines 8 10-19-2011 08:10 AM
CNC converted Drill Press compmedic General Metal Working Machines 23 01-21-2009 06:38 AM
Spade Drill Does Work in Aluminum; Big Hole Boring on Drill Press. Geof General Metalwork Discussion 47 02-01-2008 01:32 PM
Broke my Drill Press! JavaDog General Metalwork Discussion 4 09-01-2005 06:31 PM
Drill Press or Mill/Drill? cbcnc Benchtop Machines 2 03-05-2005 05:03 PM
