Old 02-19-2008, 04:12 PM
cnczoner is on a distinguished road
Does this lathe turning tool bit exist?
Hi all,
I need to turn the inside of an aluminum tube (6061-T6), with a 90-deg corner on the forward edge (the end that is not chucked). What I need is a boring bar or square turning tool bit with a 90-deg angle on the back end, sort of like my drawings below. And it should protrude about 0.2". The tube is 1.75" ID, btw.
Does anything like this exist? I haven't found it at the usual budget sources (LMS, enco, msc, shars, etc), and I haven't yet checked the specialized mfgr sources (expensive) such as seco, kennametal, etc.
Any ideas/sources on this?
Thanks,
-Neil.
Old 02-19-2008, 04:15 PM
BobWarfield's Avatar
BobWarfield is on a distinguished road
If you can't find one it's very easy to make tooling like that:
http://www.cnccookbook.com/MTMillDovetail.htm
Best,
BW
Old 02-19-2008, 04:46 PM
MazakMikeO is on a distinguished road
The one on the right looks like a standard internal grooving tool to me.
http://www.kennametal.com/en/e-catal...ategory%3A4028
Old 02-19-2008, 10:40 PM
cncswiss1's Avatar
cncswiss1 is on a distinguished road
there are internal backturning tools, for example you can get a kennametal ng (2 3 or 4) (topnotch) boting bar and stick a topnotch backturn into it (npk or npdk)
http://www.kennametal.com/en/e-catal...ategory%3A5612
http://www.kennametal.com/en/e-catal...ategory%3A5613
http://www.kennametal.com/en/e-catal...366&iPage=1xxx
http://www.kennametal.com/en/e-catal...ategory%3A4194
i think many companies make backturn inserts, finding the bar to hold it will be the trick
Old 02-20-2008, 02:00 AM
Larry83301 is on a distinguished road
Niel,
Here is another source for a bar that will do what you want.
http://www.carbidedepot.com/SearchRe...CategoryID=211
Several of these bars will backcut your part, and YES I like ISCAR. I have used thousands of their tools and inserts over the years, and had less problems with them than with the other " big name " tools.
Larry
Old 03-11-2008, 03:58 PM
Any thoughts on Circle Machine (a Kennametal brand) tools? It's not been easy reaching someone at these various companies and getting info that sounds plausible and has these tools in stock, except today I had a good discussion with a tech at Circle Machine who found me a tool and the correct inserts for this (for alum). Problem is that the tool + 2 inserts will run me $200+.
Old 03-12-2008, 07:01 AM
Andre' B is on a distinguished road
The first and last lines above are related, $200 for what is likely a low selling volume tool that you can't find elsewhere is not that bad a price.
Old 03-12-2008, 08:37 AM
Sure, and I'd spend $200 if that's what it costs, but I'm really asking if Circle Machine is a good brand, and worth that $200.
FWIW, this morning I found a different tool called "Groove N Turn" from Thinbit, which also fits my parameters and would cost me $70 for the tool and $18 for each insert. Anyone have opinions on this one?
Cheers,
-Neil.
Newbie- Fully Featured Mini Lathe, does one exist? juliancrouch Mini Lathe 10 02-09-2008 10:02 PM
Boring and Turning with the same tool? Donkey Hotey Haas Lathes 14 12-13-2007 08:45 AM
9 x 20 3/8 turning tool recommendation twocik Mini Lathe 13 06-23-2007 05:32 PM
help with turning tool offset Shizzlemah AjaxCNC Control Products 10 09-20-2006 03:36 PM
Turning Tool Steel rcazwillis General Metalwork Discussion 7 04-11-2006 08:35 AM
