Old 02-18-2008, 01:54 PM
brewtus is on a distinguished road
Cheap cnc mill
I am currently looking for some information about mills. I am wanting to start making custom car & motorcycle rims and I would like to find a cheap cnc mill that can make them. Does anyone know where I could find a cheap mill capable of doing this? Speed doesn't matter, it can be real slow with a small material removal rate. The cheaper the better! It can be used too.
Old 02-18-2008, 05:01 PM
philserveng is on a distinguished road
any used machinery dealer will be able to help, look in the yellow pages. just remember you get what you pay for, the more you can afford to pay the better. For example, choose an Okuma Cadet before a Kia.
Old 02-21-2008, 07:29 AM
JDenyer232 is on a distinguished road
Define cheap. How much are you looking to spend? Speed will most likely matter for your application. A vertical machining center can do a complex rim in roughly 40 hours or so. A cheapy underpowered machine will take much longer. Also the machine will not be as rigid, the results will be tool and chatter marks on your rims. If you are really serious about doing this then I recommend you do some research on machine rigidity. The machine will end up being a beefy machine for you application no matter what. An aluminum blank for a large motorcycle rim can weigh hundreds of pounds, your not gonna fit that in a tiny cheesy cnc mill. Just my thoughts, hope this helps.
Old 02-22-2008, 06:52 PM
prelude1911 is on a distinguished road
I have a CNC Lagunmatic Vertical Mill for sale if your interested.
Old 02-28-2008, 02:31 PM
SRT Mike is on a distinguished road
The problem with doing things like wheels is that you need a relatively big machine if you don't want to have to index the fixture... and since you must use coolant, you really want a fully enclosed VMC. So you are looking for a machine with 20" in Y, even better 25" or 30" in Y. I doubt you will get something for less than $15k, and that would be a pretty great deal and would be a 15+ year old machine.
Remember you also need hubs - and that's lathe work all the way.
Cheap overpriced MILL build log miljnor Vertical Mill, Lathe Project Log 51 09-07-2009 10:42 AM
Dirt Cheap small mill KrashKing405 DIY-CNC Router Table Machines 22 11-16-2008 10:00 AM
Simple cheap mill JBV Mechanical Calculations/Engineering Design 4 11-22-2005 05:20 PM
Want a BIG CNC Mill, Cheap? (not an ad) pfeist General Metal Working Machines 1 05-05-2004 02:09 AM
Cheap vertical mill CNCadmin General Metal Working Machines 0 01-21-2004 04:50 PM
