Old 02-18-2008, 12:00 PM
LESchwartz is on a distinguished road
Left Hand Threads
I do not currently own a lathe, but am looking to make a purchase in the near future. One of the operations I'll need to do is cut LH threads. Is this a standard lathe capability, or is there some special feature I'll need to look for?
Thanks in advance,
Larry
PS: Since there doesn't seem to be a lot of old American iron available in my area, I'm currently looking at one of the benchtop Chinese or Taiwanese machines
Old 02-18-2008, 05:31 PM
philserveng is on a distinguished road
yes, it is standard, you will only need to invert the tool and run the feed away from the spindle at the correct pitch.
Old 02-18-2008, 05:34 PM
MrWild is on a distinguished road
running the tool away from the chuck will make a right hand thread. Invert the cutting tool, reverse the direction the part turns and feed towards the chuck.
Old 02-18-2008, 06:31 PM
Thumbs up
Thanks for the help.
Larry
Old 02-18-2008, 07:03 PM
Mcgyver is on a distinguished road
you guys are making it complicated, reverse the feed and leave the tool right side up and your left hand thread will cut from headstock to tailstock. compound at 29.5 to the left and grind a left hand tool - the helix angle is in the opposite direction so the clearance angles have to lean the opposite way.....in answer to Q, yup standard stuff.
Need Help!- How do you turn a Left Hand Inside Dia. Threads rapidtraverse Haas Lathes 7 02-11-2008 01:50 PM
Why do you use your left hand ImanCarrot General Metalwork Discussion 24 10-15-2007 06:14 AM
Left Hand End Mills Medway Man General Metalwork Discussion 2 10-08-2007 01:47 PM
Left hand cutters DAB_Design General Metalwork Discussion 6 11-03-2004 09:23 AM
coverting from Right-hand to left-hand coordinate system eltonr General CAM Discussion 6 10-14-2004 08:40 PM
