Old 02-17-2008, 07:51 PM
J5P332 is on a distinguished road
Info on Johnford CNC Machines
Hello. Two questions. I'm fairly new to machining, only about 8 months under my belt. First, do machine manufacturers generally offer way protection solutions? The company I work for turns rolled rings that still have scale on them from the mill. I'm wondering if the slide covers would provide adequate protection from the scale particles or if it would be better to just buy a new boring mill instead of a lathe. Second, Has anyone used Johnford or You JI CNC Machines? If you could provide me with insight regarding either company or another you'd recommend, I'd appreciate it. We're talking 32" - 63" chuck sizes though. We don't turn small pieces on a regular basis. Thanks.
JS
Old 09-26-2008, 01:41 AM
AppEng is on a distinguished road
They are a value priced machine (Junkford) with very good support (Absolute Machine Tools). I've seen lots and lots and lots of different machines in the field doing all kinds of different work, and machine to machine, the Johnfords seem to be less ridgid and capable than a similar sized Mori Seiki, etc. There is a shop in my area who uses ALL Johnford lathes, bridge mills, vmc's. They've gone thru 3 CAT50 spindles on a 2.5 year old bridge mill, and blow belts on their lathes on a regular basis, to the point where they keep spares in stock. Fit and finish isn't quite all there, and just general "beefiness". In machine tools, you generally get what you pay for....but sometimes you can only pay for so much. You could do far, far, far worse, they work well when they work...and they have excellent support.
Old 02-22-2009, 11:12 PM
cweiss is on a distinguished road
HA! Junkford. 'nuf said!
Our customers experience the exact same things as stated here. I have paid my rent for the past year working on them.
Thanks to Johnford I live very comfortably!
Old 11-03-2009, 07:54 PM
mmilw is on a distinguished road
We ave a Johnford bridge mill with only 2100 hours and is having spindle problems. Has anyone else experienced similar issues?
Old 11-21-2011, 01:02 PM
Kevin Graham is on a distinguished road
Have a Johnford SV-41 with coolent problems. Will work through spindle and on flushing in the tank, but not on the attached hoses off to the side of the spindle. Sometimes in the morning when it has been sitting overnight, it will work but if I shut it off for any reason it stops all together. Any solutions?
Old 11-21-2011, 01:20 PM
Speeds and Feeds. Using a 3" Carbide Insert Cutter. Have to open a hole up 1.5"- 7 " deep. What feed rate should I use and speed for that cutter? It's 4140 material.
Info on Bridgeport Torq Cut 22 w/ DX 32 or other small machines?? vettespeed Knee Vertical Mills 17 10-04-2010 05:19 PM
Lots of machines no skill or setting info Stevatome General Metalwork Discussion 15 10-13-2008 05:58 AM
counter sensor problem on johnford vmc, need help wiredude CNC Machining Centers 0 05-10-2007 05:30 PM
cincinnati milacron machines? any info? stanglou General Metal Working Machines 2 12-23-2006 04:52 PM
any help with PCBoard CNC machines/info? lepton DIY-CNC Router Table Machines 5 08-07-2005 04:15 PM
