Old 02-16-2008, 01:46 PM
rsrunreal is on a distinguished road
CNC Mill conversion gathering information..
Hi, I'm a newbie to cnc, i've been lurking here for a long time reading and learning all i can..so here it goes
My goal is to build 5 axis cnc mill. My mill is exact machine that in this link: http://www.houseoftools.com/product.htm?pid=198686
My questions are:
1. AC Servo motors. How much power do i need these motors to have to stay in 250 ipm range with taking decent cuts in steel using 10 TPI ball screws?
2. AC Servo Drives. What's the basic terminology i need to know to find right drive? Also will these drives work with Mach3 or Quantum software?
3. Is using AC servo motor, drive system needs extra components in comparace with dc servos?
4th axis will be rotary head attached to the table and 5th axis will be tilting head with iso40 taper and 7,000 rpm software controlled motor
thanks, BTW great forum
EXACTO Mill information tsare General Metal Working Machines 1 04-11-2012 09:23 AM
Boxford VMC190 Conversion Information Wanted Morgo Mach Mill 4 10-19-2011 06:25 AM
Can you help with information of a JN280 Mill New Lathe Man Benchtop Machines 1 01-23-2008 08:42 PM
Vertical mill - Information needed bjinatj General Metal Working Machines 2 11-30-2007 04:36 PM
Information On The Smithy 1240 CNC Bed Mill? Willyb Smithy 26 02-25-2007 03:35 PM
