Old 02-15-2008, 03:22 PM
petriej is on a distinguished road
Help! Spindle Bearing Noise
We have a YCM60 w/ AB Bandit 4 controller that gets use nearly every day. The oddest thing happened the other day.
I was writing a tapping program in G-code. (The onboard G84 does nothing but turn on the spindle for about 30 degrees of rotation.) Nonetheless, I wrote the program and after a test run of the program, the spindle started making the strangest noise.
I have never reversed the spindle before, and even at only 500 RPM with zero load it is making noise.
So does anyone have a similar experience? Is this the spindle bearing? Any thoughts? Anyone here change out a spindle bearing on an old YCM60??
I wasn't even in material when it happened, so I am just wondering what the deal is?
Also, does anyone know good feed/speed for roll forming 4-40 in Aluminum?
Star SR20RII/Fanuc 18i, DMG CTX310V4/Fanuc 32i, DMG CTX310ECO/Siemens 8400, Mori NV5000/MAPS, Bridgeport 760/Fanuc 18i, Kiamaster 4NEII60/Fanuc 3t;Partmaker, Gibbscam
Old 02-17-2008, 04:38 PM
philserveng is on a distinguished road
this could be bearings, but you should also check drive the belts. to properly check the bearings release the belts and rotate the spindle by hand, is the noise still there ? do the bearings feel rough.check for runout using a 0.001mm indicator, check for lift in the bearings......there should be less than 0.002mm. by the way, have you got a poor surface finish?
Old 02-26-2008, 01:15 PM
Surface finish has degraded a tiny bit. But we are also running higher feedrates. Surface finish is now the cut lines from the tool. It was previously clean.
It seems to be the bearing on the top of the head at the drive pulley - I moved the quill to the end of its stroke and the noise stayed in the same place.
Spindle Noise FXRGUY Daewoo/Doosan 4 01-29-2008 04:20 PM
How do you deal with the noise from the spindle pulley? david_geng Syil Products 0 07-08-2007 06:03 AM
Way Oil and Spindle Noise ETM Shop Syil Products 14 01-28-2007 09:06 PM
Porter cable spindle noise reduction or alternative? paulr4 DIY-CNC Router Table Machines 6 03-26-2005 12:56 PM
spindle electrical noise balsaman General Electronics Discussion 9 10-21-2003 08:41 PM
