Old 02-13-2008, 05:07 AM
Lance Reid is on a distinguished road
Newbie questions
Hi all, have just bought a small Chinese manual mill to learn some machining, couple of queries;
1, the deck has no drain holes in it, is it possible to drill and tap a drain hole with a hose down to a coolant pump or is coolant not required?
Depending on the materiel?
Cheers, Lance
Old 02-13-2008, 05:55 AM
Rally's Avatar
Rally is on a distinguished road
Coolant holes should be placed in the center of the open pockets on either end of the table. 1/4" Pipe will do. Drill hole to where you are slightly lower than the bottom of the pockets that will ensure everything draining out.
All comments made are my opinion!
Old 02-13-2008, 12:12 PM
juliancrouch is on a distinguished road
It sounds like you are working towards a CNC flood system? In which case it would be easier to drain from the edges of the table...
If you are not CNC, you could mist, or just apply your cutting fluid manually.
OM newbie questions emceul Fanuc 2 10-10-2006 11:11 PM
Newbie with questions SlideRule Benchtop Machines 10 03-25-2006 12:13 AM
newbie questions seware74 PicStep Controllers 0 01-11-2006 10:44 PM
Newbie Questions Todd Price DIY-CNC Router Table Machines 5 04-16-2005 08:31 PM
Newbie and some questions..... skymaster DIY-CNC Router Table Machines 2 09-12-2004 05:11 PM
