Old 02-12-2008, 05:42 AM
fisherb is on a distinguished road
BSA Churchill Tailstock stuck
I have recently acquired a Churchill two series cnc lathe, it works nicely, however I can't seem to be able to remove the tool from the tail stock, no reference to it in the manual either. Can anyone shed any light on this?
Old 02-13-2008, 12:02 PM
The picture I got when I googled BSA Churchill serirs 2 appeared to be a CNC chucking type lathe without a tailstock. Evidently not the exact duplicate.
You mention a tool stuck in the tailstock. Is this a taper shank tool in the tailstock or a straight shank tool stuck in a turret station or?
I've seen a bearing removed by WARMING up the housing with a heat gun and very light oil allowed to be "sucked in" as it cooled. The bearing was easily removed later.
Might help, Dick Z
DZASTR
Old 02-13-2008, 12:11 PM
Dick:
Its a taper tool (drill chuck) stuck in the tail stock. Cant seem to work out how its meant to come out as there is no room for a drift and no button to do it auto!
Old 02-13-2008, 12:51 PM
Normally, you just crank the center spindle or quill backwards until the end of stroke. The tool or center taper comes into contact with an internal stud that knocks the tool loose. Be prepared to catch it as it pops out. In rare cases, the tapered shank is shorter than standard. Generally the screw can be removed from the tailstock and a soft (brass) metal rod is "applied" to knock the tool out. Then the offending tapered shank is sent to the scrap bin or a "nub" welded on the end to restore the correct length.
Personally, I prefer the scrap bin. I don't like to use tools that have been welded. Just me.
Dick Z
DZASTR
Old 02-13-2008, 06:15 PM
gridley51 is on a distinguished road
On most cnc lathes the tailstock is only designed to hold a centre.The type you should use in the Churchill and many other ones has an external thread with a nut to jack it out of the taper.I have had this problem myself on other machines and found the easiest way to get it out is to grind a notch in the centre/tool and drift it out with a punch and hammer.At the very worst you could weld something on to punch against but that would be a last resort.You could always ask the BSA service dept for help/info on 0121 783 4071.
I have three Churchill lathes,3/15,4/10 and a CTC4 and have always found BSA to be very helpful.
Mark.
Old 02-14-2008, 02:19 AM
Gridley51,
I know it may be a lot to ask, but I would be extremly grateful if you could find the time to send me a picture of what you mean. I think I understand but I just want to be sure before I go ruining the taper thats in there getting it out and having nothing to put back in. Also, have you any idea where you can buy such a thing, other than BSA? Can't seem to find any in any tool shops online or otherwise,
Cheers
Old 02-14-2008, 10:35 AM
fisherb, try this http://www.riten.com/products/dead_c...rs/default.asp
Dick Z
DZASTR
Old 02-20-2008, 02:04 PM
fisherb, you still with us?
Dick Z
DZASTR
Fanuc 10T on Matric Churchill F.Sharifi Fanuc 1 01-07-2008 05:12 PM
Tailstock M-Code? gcrudgington Daewoo/Doosan 1 09-28-2007 08:42 AM
Right pressure for tailstock jani General Metalwork Discussion 12 03-05-2007 10:45 AM
TL-2 tailstock rbest27 Haas Mills 2 11-10-2006 05:20 PM
Churchill ctc3 error abselect General CNC (Mill and Lathe) Control Software (NC) 0 06-22-2006 07:09 AM
