Old 02-03-2008, 12:18 PM
KEVNO is on a distinguished road
CONTROL PROBLEM
I'm having a problem with my Anilam Crusader series M . the machine starts up and runs but sometimes the control will kick the servos out. the display blinks and the X,Y,Z display 000"s and xxx"s. Anyone have an idea where i should start looking? I know the control is out dated, and it's not worth having a service man look at it. But the machine serves a purpose at the shop every once in a while.
Old 02-05-2008, 12:36 PM
philserveng is on a distinguished road
you could have a motor encoder problem (or a linear scale fault if it has them). make sure the measuring system plugs on the motors (and scales) and tight, they do come loose and vibration causes problems. make sure all the cnc boards are pushed in and the connectors are secure. do you have an anilam manual to refer to? if so look for possible help there.
Old 02-09-2008, 05:42 PM
bkstoffe is on a distinguished road
If you do narrow your issue down to a board, I do buisness with a local indusrtial electronics repair center. They have fixed my series M servo boards and also my graphics card in the control. They are reasonable, and can fix anything - even the monitor. PM me if you need contact info.
B
Old 07-30-2008, 06:10 AM
Maurice is on a distinguished road
Anilam Crusader series m
HI
Need help with an Anilam controller Series M. The crt don't won't to light up. I'm having just a small flashing point in the center of the screen. The axis still feed
Regards
maurice
Old 08-04-2008, 01:31 PM
DanC is on a distinguished road
I read in another thread that you can use a commputer monitor with the Anilam controller since it's PC based. Not sure if thats true.
Old 08-07-2008, 09:30 AM
Thanks will check it out
Maurice
Problem with syil x3 cnc control... scyan Syil Products 3 03-29-2007 11:11 AM
Stepper control problem climberfreak66 Stepper Motors and Drives 7 10-29-2006 05:24 PM
Fanuc control problem wilsontool Fanuc 0 10-12-2006 01:56 PM
Problem with old GE 7542 control. NcDave Machine Problems, Solutions , Wireless DNC, serial port 4 07-03-2005 09:41 PM
DC speed control problem Swede General Electronics Discussion 6 02-07-2005 09:06 PM
