Old 01-31-2008, 09:19 AM
gregoryblaine is on a distinguished road
Smile mazak m2 control
does someone know how to stop this control from ending a program with no tool? Every time it comes to the end the machine puts tool away and leaves the spindle empty. I am only using 1 tool and there is no reason to put it away. can someone help me out
thanks greg
Old 02-01-2008, 08:53 AM
cut more is on a distinguished road
Greg,
I have an MO control on my VMC which is older that yours. Take a look at the end of your gcode file. If there is a toolchange command in there that would do it. I use Bobcad to generate my g-code and the "end program" macro adds a t1 m6 to the end lines of the program. I will be changing that soon!
If there is no toolchange command then there would probably be something in the parameters that tells it to do that.
Hope that helps,
Cutmore
Old 02-04-2008, 02:36 PM
Brakeman Bob is on a distinguished road
thanks greg
OK, it has been a long time sine I was using M2 (about 15 years) but if memory serves, right at the end of the program is, naturally, the END PGM statement and in there there are two fields that can be either 1 or zero. One of those is the flag to return to the calling program (like M99) and the other if set to zero puts all the tools away, if set to one, loads the first tool of either this program or the calling program.
Let me know if I am right (it is comforting to know you haven't forgotten everything you once knew).
All the best
Bob
Mazak Variaxis 500 accuracy control dolphin1 Mazak, Mitsubishi, Mazatrol 0 06-20-2007 02:42 PM
Mazak / Yasnak MX3 control toolsetter soszi1950 Mazak, Mitsubishi, Mazatrol 1 02-10-2007 08:24 AM
Mazak VTC41L yasnak control +programming soszi1950 Mazak, Mitsubishi, Mazatrol 7 01-31-2007 07:11 PM
Mazak EIA Control RS232 Connections jonbcnc Mazak, Mitsubishi, Mazatrol 2 11-20-2006 02:34 PM
mazak v-5 w/fanuc 6m control nc fuse light?? wild01 Fanuc 2 07-11-2005 04:05 PM
