Old 01-30-2008, 04:55 PM
HiTech is on a distinguished road
Kitagawa B-08 Power Chuck
Our Kitagawa B-08 power or hydraulic chuck is getting a little sloppy and needs to be rebuilt or replaced. Can we rebuild it ourselves? Can you recommend a rebuild outfit if rebuilding it ourselves is not very practical? Thanks!
Old 02-05-2008, 08:52 PM
ragman is on a distinguished road
They are easily rebuildable. The biggest issue is getting them unscrewed from the draw tube as usually there is a lot of corrosion in this area. Spares are readily available.
Old 02-06-2008, 09:50 AM
neilw20's Avatar
neilw20 is on a distinguished road
Exclamation It's heavy!
You can set up a big boring bar to support the chuck as it is removed.
Make sure you pull the breaker for the spindle drive, or remove the belt.
Consider safety having the machine alive to move in X and Z while working to remove the chuck. Only use jogging to move an axis. Have a competant assistant near the emegency stop button.
Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
how to install power chuck on sl3b Andy Fritz General Metal Working Machines 2 09-08-2008 10:01 PM
How to remove 12" Kitagawa chuck from LC40? SRT Mike Okuma 15 11-23-2007 07:05 PM
Kitagawa B-12 petriej General Metal Working Machines 3 09-25-2007 06:02 PM
Kitagawa autodex MacMini controller soszi1950 Ability Systems - LPT Indexer and G-Code 0 06-09-2007 05:26 AM
How to use Power Lathe Chuck John3 General Metal Working Machines 13 04-08-2007 09:38 PM
