Old 01-29-2008, 05:02 PM
billystein is on a distinguished road
need nigata mechanic.
a freind of mine needs a mechanic to fix his nigata en50. trouble with rotary and pallet changer. looks like limit switches but I'm not sure.
thank you
billy
Old 01-29-2008, 05:46 PM
philserveng is on a distinguished road
You need to remove all pallets to the pallet stations, check they are on their park switches. Clamp the rotary table without a pallet and close the work area door, reset and power off. When powered on, the control should know where the pallets are and have no alarms. If you still have problems, it could be limit switches or even the contact pressure switch in the rotary table (if it exists).
need serviceman for nigata en50 billystein CNC Machining Centers 1 02-10-2008 10:02 AM
Nigata Fanuc 3M nastek Fanuc 3 06-30-2007 09:31 AM
