Old 01-28-2008, 02:34 PM
SV in SD is on a distinguished road
Boring Tool as an end mill?
Hello all!
This is a great website with lots of information. I am loving it as someone who is just getting into metalworking. For a first post, I have a couple of questions concerning a Criterion Boring Tool.
I have used it a few times on a vertical mill for boring round holes. However, I am curious to know if it is 'safe' to use this as I would an endmill? The forces on the tool would be perpendicular to what it is designed to do, but it seems that small cuts and a slow feed rate should be ok.
Also, has anyone used one of these for boring on a lathe?
Thanks,
Chris
Old 01-28-2008, 03:41 PM
Mitsui Seiki's Avatar
Mitsui Seiki is on a distinguished road
You can use it when counter boring to get the right depth.I wouldn't recommend using it for anything else.
Stefan Vendin
Old 01-28-2008, 03:59 PM
Glad I asked!
Thanks for the reply.
Old 01-28-2008, 04:12 PM
dapoling is on a distinguished road
Originally Posted by SV in SD View Post
Hello all!
Thanks,
Chris
In a simple answer, No. and it will not produce a flat bottom for a counter bore.
My Response to "It's Close Enough", "Is Your Tool Box and The Door Close Enough?"
Old 01-28-2008, 04:16 PM
mxtras's Avatar
Silver Member
mxtras is on a distinguished road
Fly cutters are a lot cheaper and more robust. They are also cheaper to tool up. I am assuming you are thinking about using it to face. If not, get yourself an end mill for side milling.
As far as using it on a lathe - yes. You can do that. Not sure why but I can see where if you were doing multiple operations on a manual lathe how it could be handy if used in the tailstock to provide the finish on an existing hole. Was that your intention?
Scott
Consistency is a good thing....unless you're consistently an idiot.
Old 01-28-2008, 04:25 PM
It will if you have the right insert.Been doing it for years.
Stefan Vendin
Old 01-28-2008, 04:52 PM
I do not doubt you have been doing it for years, was it designed for that , no. Why damage a $500 plus tool when a $10 endmill or counterbore tool or even a $1.50 drill ground to a flat bottom will do the job?
A decent boring head will produce bores with in .0002-.0003 all day if it is in good shape.
About the lathe, they have boring bars readily available that serves the purpose , I would never use a boring head for a mill in a lathe.
One must respect and take care of their tools and equipment, without them you do not have a job.
Use the right tool for the job.
Old 01-28-2008, 05:35 PM
The tool is not designed for it,I know that.We remove .0008 and the tool is fine.
Why use an extra tool if you don't have to?
I had a little word with Sandvik Coromant before I decided to do it...
They said I could go as far as .001 without damaging the tool.
I got a $1000 bonus for the idea.
Stefan Vendin
Old 01-28-2008, 05:52 PM
I have retracted what I was going to say in disagreement, but I do stand by what I said above.
Old 01-28-2008, 06:26 PM
.....Use the right tool for the job.
But you have to define 'right'.
One definition I use is:
The tool that performs the necessary operation to within the required tolerance at the lowest cost.
When I worked for other people I sometimes got flack because I was applying this principle and using the 'wrong' tool. In my own business it applies all the time.
  #11   Ban this user!
Old 01-28-2008, 06:30 PM
Can you be more specific ?, what tool what use....
  #12   Ban this user!
Old 01-28-2008, 07:27 PM
cam1 is on a distinguished road
That's what I love about this trade. 10 people can be given the same job, and will invariably use different methods to produce identical results. The difference sometimes is just the time it takes, and the tools they choose to use.
cheers
who makes a good boring head for x2 mill mopar92 Benchtop Machines 4 01-11-2008 11:10 AM
Boring and Turning with the same tool? Donkey Hotey Haas Lathes 14 12-13-2007 08:45 AM
Horizontal and Vertical boring mill operators quinnj Employment Opportunity 0 10-16-2007 01:58 PM
New Photos! Horizontal Boring Mill (30HP) mzartop6 CamSoft Products 1 09-11-2006 08:11 PM
ceruti boring mill schematics bennett71 General Metal Working Machines 0 11-04-2005 02:28 AM
