Old 07-12-2004, 03:54 AM
sendkeys is on a distinguished road
Question Angular Contact bearing question
Old 07-12-2004, 10:25 AM
HuFlungDung's Avatar
Moderator
I don't think it would matter too much. The higher precision bearing allows you to run the bearings at a higher speed with less heat build up. Unless you plan to run the ballscrews at continuous high speed, you will never get any amount of heat from that source.
In a low precision bearing, it may actually be only two or three balls that carry the actual thrust load. That's what you have to settle for, because the balls are not selected for precision size.
Old 07-12-2004, 07:45 PM
ahh great this will save me some money i should never go over 2.6k rpm so i dont think heat will be a big deal
Ballscrew Basics Swede Linear and Rotary Motion 94 09-06-2011 07:23 PM
Ball screw angular contact bearing block dowling177 DIY-CNC Router Table Machines 0 03-15-2005 03:03 AM
Ball screws and angular contact bearings? dowling177 Mechanical Calculations/Engineering Design 1 01-27-2005 04:21 PM
Bearing Block Question Moondog DIY-CNC Router Table Machines 4 08-22-2004 07:06 AM
Angular Contact Ball Bearing ? sendkeys General Metal Working Machines 2 06-24-2004 03:06 PM
