Old 01-26-2008, 12:25 PM
zaid is on a distinguished road
How to convert Manual Lathe to CNC Lathe?
How to convert Manual Lathe to CNC Lathe, without purchasing kit if possible. I am new in this matter.
Old 01-26-2008, 12:40 PM
Al_The_Man's Avatar
For one, you will need to replace the Acme screws with ball screws, there has been several past threads here covering the steps for the conversion procedure.
Old 01-29-2008, 11:17 AM
mackeym is on a distinguished road
You'll also need servo or stepper motors and a drive for each motor. It's good to have a servo spindle too, but this isn't a necessity.
Old 01-30-2008, 03:42 PM
The Blight's Avatar
The Blight is on a distinguished road
You dont need a servo spindle. What you "need" is an encoder so that it knows at what speed its turning. If you want to do milling jobs on the lathe with live tooling, you should consider making it sort of a servo with a break.
You can even do with regular Acme screws, but there are more friction in them, and they have more backlash.
Other then that, you will need (as mackeym allready pointed out) servos or steppers with drivers (one for each motor), and a powersupply. You will also need a breakout board for connecting the drivers to a computer.
Old 02-07-2008, 12:42 AM
Thanks, Al The Man, mackeym and The Blight for your replies. I have search the net for this and found following artical useful :
http://www.dakeng.com/CNCconvert.html
But I need more detailed, information for the same.
manual lathe convert cnc/manual lathe kakayo Vertical Mill, Lathe Project Log 3 02-21-2010 01:13 PM
Convert Taig Mill into lathe? youthebest Taig Mills & Lathes 4 11-19-2007 08:26 PM
Convert a lathe to a cnc lathe Tompie General Metal Working Machines 1 09-21-2006 08:41 AM
Lathe: convert PULLEY to GEAR? lepton Mechanical Calculations/Engineering Design 0 12-13-2005 11:22 AM
Lathe:convert PULLEY to GEAR? lepton Mini Lathe 0 12-13-2005 11:19 AM
