Old 01-20-2008, 08:02 PM
Spinnetti is on a distinguished road
Speeding up drilling on a lathe..
Hi All.
I've been doing lots of deep drilling on my lathe, and its a total pain having to spin that little wheel on the tailstock over and over. Any parts out there, or ideas to make it with some kind of rack an pinion and a big lever? I don't need huge amounts of force, just want it to work like you can do on a mill. I have a Grizzly 12x37 or so gap bed mill.
TIA..
Old 01-20-2008, 11:41 PM
Kiwi is on a distinguished road
Add a flange to the handwheel to create a drum. Thread a chord over a pulley attached to a rafter and down to the drum. Add a weight to the other end of the chord. When you turn the handle the chord will windup the weight. To unwind just pull the chord.
I do this with my compound feed when doing repetitive passes.
Option two would to start the hole in the lathe and finish in a drill press.
Old 01-21-2008, 12:00 AM
toastydeath is on a distinguished road
Mount the drill in your cross slide.
Old 01-21-2008, 06:45 PM
pastera is on a distinguished road
Add a lever feed to your tailstock
http://www.kinzers.com/don/MachineTo...etailstock.jpg
Aaron
Old 01-22-2008, 08:03 PM
Runner4404spd is on a distinguished road
get a quick change tool post and get a holder for an MT taper and mount the drill into that then you can use the saddle to run back and forth as opposed to the little tiny crank at that back.
Old 01-22-2008, 08:28 PM
What size drill is being used?
I would have thought using the saddle to hold a drill (eg. 3/8" plus) would be putting excess loading on the working parts.
Using the tail stock gives a direct force with good leverage.
Old 01-22-2008, 09:13 PM
The saddle is usually equal to or more rigid than the tailstock. I'm not familiar with the smallest lathes, but I don't see why it wouldn't work just fine. If you can securely hold the drill, there's no problem doing it this way. You get power feed for the full length of the drill, and a quick retract.
Old 01-23-2008, 03:42 AM
I guess it's depends on the material being drilled, the size of the drill and the size of the lathe.
When using the saddle there must be considerable twisting taking place as the rack for the drive is way out line with the drilling axis. Are the saddles guide-ways designed to with stand these forces?
When using the tail stock these forces are inline.
Old 01-23-2008, 05:02 AM
Baketech is on a distinguished road
I know I will get flayed for this, but if I have a lot of repetitive drilling like that, I use my cordless drill to motor the tailstock in and out...
Old 01-23-2008, 07:01 AM
gridley51 is on a distinguished road
If you can`t use the toolpost to mount a drill,or make bracket for the crosslide to hold the drill,then make a bracket to connect the tailstock to the saddle.Leave the tailstock free to slide and tow it with the saddle in power feed.
Mark
  #11   Ban this user!
Old 01-23-2008, 07:05 AM
LOL... You are a creative bunch!
Thanks Guys!
I'm just drilling .250 holes in a aluminum the full depth of the bit - takes LOTS of chip clearing. Those were all creative solutions to the same problem. Having worked in a production environment years ago, I have no patience for doing anything slowly! The best of the bunch is what "Pastera" posted - thats EXACTLY what I was looking for, I just needed to visualize it - Thanks! I suppose if that is ever not strong enough, I can get another tail stock or put the wheel back in, but generally it should be perfect.
PS, "Baketech" I've done worse, like duct taping my right angle grinder to my tool post when I was doing the ball screw conversion on my mill! (it worked great too!)
Here's what I'm making: Almost exact scale landing gear for R/C planes, in this case a WWII fighter - the FW190 - Still have a few more ops to do on these and are a great case to CNC my lathe. (Pics are of early working proto and latest version in progress)
ID:	51469   Click image for larger version
  #12   Ban this user!
Old 01-23-2008, 08:09 AM
Cool little project...FW190's are awesome!
Speeding up look ahead on a Haas controler conceptmachinin General CNC (Mill and Lathe) Control Software (NC) 0 08-24-2007 09:55 PM
Deep drilling on cnc lathe jackson CNCzone Club House 10 12-21-2006 04:13 PM
Drilling advice on CNC Lathe motter71 General Metalwork Discussion 2 12-06-2006 09:02 AM
stepper speeding up and stalling?? chrisw765 Stepper Motors and Drives 2 03-18-2005 01:00 AM
speeding up X axis IPS pminmo DIY-CNC Router Table Machines 12 08-19-2004 02:30 PM
