Old 01-20-2008, 06:49 PM
wdp67 is on a distinguished road
Tailstock loosing zero when moved
Hi all
Just purchased a 11x27v Precision Matthews lathe. It seems to be a really well built lathe. Everything works great except the tailstock. Using an indicator in the chuck, I zero'd the tailstock. I then loosened the tailstock and moved it out of the way, loaded my part and started cutting. It was cutting a taper, so I adjusted the tailstock so that it cut straight.
When I was done with the part, I moved the tailstock and for grins tightened it back down and checked it for zero again and it was offby .010-.015. I zero'd it again like before, then moved it and tightened it back down, and everytime it is off by varying amounts.
Any thoughts? What can I do?
Thanks a bunch
Walt
Old 01-20-2008, 07:22 PM
HuFlungDung's Avatar
Moderator
Have you called the dealer? I can hear it now "They're all like that"
Take the tailstock off and check for any obvious nicks or burrs. Check it for stability in case it has become warped on the bottom for some reason. Check between the base (where the setscrew push against) and the upper body of the stock for paint chips etc that could allow it to wobble.
Old 01-21-2008, 10:26 AM
I have an e-mail in with the dealer now, have not heard anything though. I kind of checked the tailsock over, and do not see anything that would cause it.
Walt
Old 02-18-2009, 01:38 PM
Wintermute is on a distinguished road
I was wondering if you got this resolved. It sounds to me like your set screws on the tailstock may not be tightened which is allowing it to move when the tailstock is tightened to the ways. If possible, please provide an update
--Wintermute
--Wintermute - http://www.improvised-engineering.com/
"No man's knowledge here can go beyond his experience." - John Locke
moved? HMD Plasma, EDM and other similar machine Project Log 1 12-04-2007 05:04 PM
Moved: Emcomat V8 parts????? dfstrasser Vertical Mill, Lathe Project Log 0 04-15-2007 02:48 PM
