Old 01-14-2008, 02:44 PM
slatern44 is on a distinguished road
Rotary Compressor
I'm in the market for a new rotary compressor and was wondering what brands others are using and if they have had any problems. I need a 10HP model so I can get around 35-40 CFM's out of it. I bought a Eaton pump compressor last year and that was a big mistake now I need to buy a good rotary one that will last for many years.
Thanks,
Neil
Old 01-14-2008, 04:56 PM
mll mll is offline
mll is on a distinguished road
Look into Elmo Rietschle
elmo Rietschle is a world leader in vacuum pumps and conpressors
there site is http://www.rietschle.de/rtpumps/de/sch/en/home.nsf/ , I resell for them if you find anything from them that you are interested in let me know.
Mike
Old 01-14-2008, 05:20 PM
I have had a Kaeser 30 CFM unit (7.5hp) for four years now (over 8000 running hours). It gets regular maintenance for oil and filters on an annual service contract from the supplier and the only part needing replacement has been the solenoid on the unloader valve.
I recently bought a second one because we had added machines so a single unit could not keep up; actually for about a year the Kaeser was running at 100% capacity with an ancient Atlas Copco backing it up when needed.
The Atlas Copco incidentally has 45,000 hours on it and it still gives 45 CFM out of a unit that could originally do 60 CFM.
Both the Kaeser and Atlas Copco are the type that have the motor running constantly with the compressor cycling betwee idle and load; this means you do not have frequent large starting loads.
HELP rotary converter for air compressor gman1487 General Electronics Discussion 0 06-03-2007 11:22 PM
Chicago rotary compressor to run VF2 joesimmers Haas Mills 1 04-16-2007 10:04 PM
Compressor Crazycorkey Jet Engines and Ram Jets 8 01-30-2007 03:02 AM
rotary air compressor omegaghost I.C. Engines 5 01-14-2007 06:19 PM
can a blower be turned into a rotary screw compressor? jderou Mechanical Calculations/Engineering Design 16 12-08-2005 06:53 AM
