Old 01-05-2008, 12:56 PM
jeff8451 is on a distinguished road
dc spindle motor
I aquired a old makino machining center.
It has 3000c controls and a fuji dsr 83 spindle control, with a fuji ggg 31386 motor.
I am retro fitting the controls to rutex. Does anyone know something about the spindle motor, and drive?
I am mostly interested in motor wiring. I am convenced it is a series motor with 5 wires, 3 to the field.
any ideas?
Old 01-05-2008, 01:03 PM
Al_The_Man's Avatar
Not familiar with that particular motor, but I would be very surprised if it was a series motor for a spindle, more than likely shunt wound.
Most of the older DC spindles were 3 phase SCR drives.
What HP is it?
Old 01-05-2008, 01:12 PM
motor
The motor it 5.5/7.5kw 0r around 10hp. there is a 4 speed trans under it. i hooked the motor up to dc and it runs. I tried the kbcc225r last week, and it blew the fuse. the field now measure 22 ohms. the drive has connections for motor thyristors. This is a very large machine. anyone need 3000c stuff?
Old 01-05-2008, 01:17 PM
what is scr?
Old 01-05-2008, 02:22 PM
Al_The_Man's Avatar
SCR Silicon Controlled Rectifier, it generally pre-dates PWM (Pulse Width Modulated) drives.
One advantage is you do not need a large DC supply like you do with PWM.
Using a a phase shift control method, it uses the controlled rectifiers in a full wave bridge to vary the AC input energy to the DC motor.
Spindle Motor Bobbyr70 Phase Converters and VFD 3 10-09-2007 10:43 AM
Servo motor used as spindle motor? fatal-exception General Metal Working Machines 6 09-14-2007 03:55 AM
more rpms for spindle motor and spindle bob1112 Mechanical Calculations/Engineering Design 33 02-10-2007 02:01 PM
Spindle Motor Help Ringleboy26 General Electronics Discussion 3 01-04-2007 12:25 AM
AC or DC as spindle motor? svenakela General Electronics Discussion 0 10-06-2005 05:02 AM
