Old 01-02-2008, 01:08 AM
mackeym is on a distinguished road
Bison vs. Buck 6-jaw 6" chuck
I'm looking into getting a 6" 6-jaw chuck and deciding between buck and bison (or other quality brands). Is the extra money for a Buck worth it...or are they pretty much the same as Bison chucks? I've ruled out the cheap imports because i think they'll be low quality.
Old 01-02-2008, 05:06 AM
Zumba is on a distinguished road
The buck has pointier jaws, allowing it to close quite a bit more than the Bison. If you don't have a collet chuck and plan on turning small diameter rods, then the Buck is the better choice.
I have a Bison Set-Tru 3-jaw and love it.
BTW, any particular reason why you're going with a 6-jaw? My 3-jaw has blunt jaws, but the nature of 3-jaw chucks is that they close pretty far regardless.
Old 01-02-2008, 09:06 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
I don't know anything about buck.
I really like Bison and usually go to them first for my "chuck-type" products.
www.integratedmechanical.ca
Old 01-02-2008, 09:11 AM
Originally Posted by Zumba View Post
...BTW, any particular reason why you're going with a 6-jaw?....
One reason to have a six jaw available is that you can remove two opposite jaws and then hold square stock running true.
Old 01-02-2008, 11:07 AM
The 6-jaw is a little more versatile also because it can better hold thin walled work. The higher number of jaws translate into less force per jaw for the same total clamping force compared to a 3-jaw chuck.
Old 01-02-2008, 11:10 AM
ok, thanks. It sounds like the Buck and Bison are pretty much the same except that the Buck can hold smaller diameter work (especially with the solid jaws).
Old 01-02-2008, 11:26 AM
Has anyone had any experience with Enco brand chucks. For a 6" 6-jaw chuck, the price comparison is: Bison-$484 Enco-$304 and Buck-$997. Enco is by far the cheapest, and if the quality is equivalent, i might as well get the Enco chuck.
Old 01-02-2008, 11:33 AM
Make sure you are comparing identical chucks. The Bison probably has removable top jaws but the Enco may be solid jaws. The removable top jaws can be turned around for holding large diameter parts and it is possible to make custom top jaws. This can be very useful for odd-ball parts.
Old 01-02-2008, 11:47 AM
Hmm...wow. I never thought about that. That's a good idea
Old 01-02-2008, 12:10 PM
diecutter is on a distinguished road
When I bought my Bison 6 1/4" 4 jaw chuck about 15 years ago, they told me there were two grades, production and precision. The precision grade was about 20 percent higher cost. I bought the higher grade and am quite happy with it. You might want to ask them about this.
I like the 4 jaw since you can put round or odd shaped parts in it. Also, you can eliminate the runout on round parts which you can't on a 3 jaw scroll chuck.
Old 01-02-2008, 12:47 PM
DareBee's Avatar
That is true, Bison still comes in at least 2 grades.
To a certain extent, you get what you pay for.
IMO by the time my guys wreck the Bison semi-steel chucks, they have paid for themselves and I buy new.
The Chinese chucks that came with the lathes didn't last a year.
There is nothing wrong with the initial quality of the China chucks, but the material must be too soft (or something).
  #12   Ban this user!
Old 01-02-2008, 03:37 PM
skmetal7 is on a distinguished road
Replacing 8" Kitigawa chuck with a 10" on Mazak SQT15 BerkoB CNC Tooling 0 10-05-2007 01:39 PM
New 6 Jaw Buck Chuck Backplate Woodenspoke General Metalwork Discussion 6 01-21-2007 03:22 PM
Brown & Sharpe Permanent Magnetic Chuck. 5" X 10". dertsap Metal Working Tooling 1 10-13-2006 08:26 AM
4" 4 Jaw chuck mjarus Mini Lathe 9 04-07-2006 08:59 PM
Bison tooling any good? carbidecraters Fadal 9 02-01-2006 01:42 PM
