Old 12-30-2007, 04:23 PM
HOLYCNC is on a distinguished road
i need cnc routing-milling machine
i need a little cnc machine for fast prototyping pcb that contains TQFP 64 pin ic packages. can i achieve this resolution-precision with using gecko 203 drivers for 3 axis, 1.8 degree stepper, and proxxon mf70 ?
is there any good , low cost alternative? http://www.k2cnc.com/shop/proddetail...%2D2514&cat=26
what is your opinion about this product? has it anought precision?
Old 12-30-2007, 04:47 PM
rustamd is on a distinguished road
if you need something small, consider one of these: http://cgi.ebay.com/WidgitMasters-Pr...QQcmdZViewItem
a very nice machine that member Widgetmaster makes.
Old 12-30-2007, 05:06 PM
how can i trust that specifications? and which one is more suitable because prices of them are close and k2cnc gives steppers.http://www.k2cnc.com/shop/proddetail...%2D2514&cat=26
is gecko 203 right choice?
what is the most little milling-cutter pen? is 0.01 mm possible?
Old 01-02-2008, 05:02 AM
jalessi's Avatar
jalessi is on a distinguished road
To a get a system that will hold .01mm you are going to spend alot more than any of the machines you are looking at
Old 01-02-2008, 05:30 AM
for example? how much money will be enought? and is there any example around , i wantto see it.
and how many mm can i hold with these (k2cnc machine) machines?
Old 01-02-2008, 05:53 AM
jalessi's Avatar
Holycnc,
The machines you mentioned might hold .025mm, I would look at a Minitech if you are serious about holding .01mm or better.
http://tinyurl.com/28dtub
Also you might want to look at a NSK Astro Spindle Motor because the runout might be a problem otherwise.
Plan on spending about $12,500.00
Take care,
Jeff...
See attached link
http://www.minitech.com/itemdesc.php?ic=3
Old 12-08-2008, 03:37 AM
ivan_j is on a distinguished road
www.accuratecnc.com
I have A360 (USB2.0) with camera (~9000$) - really good machine !
Old 12-17-2008, 10:01 AM
Example (produced with A360):
- TSSOP 38 pins with 8 mils pads and 7.5 mils insulation + full
copper rubout. Manufacturer states 4 mil traces, 4 mil insulation are OK.
- screen shot from the software
ID:	71728   Click image for larger version
pacer routing/milling machine woodman-46 CNC Machining Centers 12 01-16-2009 08:01 PM
New To Cnc Routing And Milling mike robson Europe Club House 0 03-26-2007 04:50 AM
Large Planing/Milling/Routing Table UrbanLogger DIY-CNC Router Table Machines 14 01-11-2006 04:29 PM
