Old 06-29-2004, 06:08 PM
pigifly is on a distinguished road
Best way to mill a dovetail like cut ?
Hi all.
Hope this is not off topic here.
I need to cut a rectangular alluminium piece to create a dovetail joint as explained in http://wapics.free.fr/machines/fraiseuse/pparonde02.gif but I dont own yet an angular vise to keep the piece and the mill I own is able to rotate the motor only toward the Y movement, which is too short to work a 20 cm piece.
Can you supply me some ideas to achieve this resultat without buying the vise, and using only 4t end mills ( if this is possible ?)
Pigi
P.s. Sorry for my bad english, and ask me if this is not clear
Old 06-29-2004, 07:48 PM
wms's Avatar
wms wms is offline
Moderator
wms is on a distinguished road
Pigi,
You could use either a tapered end mill or angle blocks.
Both are fairly cheap and easy to use.
DLMACHINE is on a distinguished road
I suggest ordering a dovetail mill. It already has the profile. Then I would make the dovetails out of single pieces instead of bolting together as shown at the link you provided.
Old 06-29-2004, 10:04 PM
3t3d is on a distinguished road
Re: Best way to mill a dovetail like cut ?
Originally posted by pigifly
Hi all.
Pigi
Back before I had CNC or angle blocks, I made really quick angle setups by having a scrap plate bolted to the table, about 20mm thick. Just drill a hole for a dowel pin, zero the dials, and calculate the postion for the second dowel to create any needed angle.
Slide the stock against the dowels clamp, and cut in a straight cut in X or Y axis.
This method will allow you to make a really quick and simple jig to hold your parts to cut the angles. Especially if you do not have a dovetail. Improvise.
Pete
Old 06-30-2004, 03:55 AM
To DLMACHINE
I suggest ordering a dovetail mill. ...
It would be really better, but there are a couple of problem:
1) my mill ( actually ) can't handle a dovetail mill as the chuck is too little in dia form them ( max 6mm )
2) the dovetail mill has a too high cost, that I prefere to spend in cnc"fying" my mill
3) I don't think I would use it more the few times, so it's better to invest those money in ( eg ) an agular vise
Thanks anyway.
To 3t3d
improvise ...
That's the idea
Thanks to all
Pigi
Old 07-02-2004, 04:23 AM
RotarySMP's Avatar
RotarySMP is on a distinguished road
I built my T-slotted cross slide like this. You can either bolt the strips of steel to a Hex bar to set them at 60° for milling, or just file them like I did cause I couldn't swingt hat length on my lathe.
http://www.wrathall.com/Interests/ma...oss_slide1.htm
There is a link to an old article by Martin Cleeve which shows a lathe setup to face the 60° angle with a hex bar on the faceplate.
Regards,
Mark
www.wrathall.com
Old 07-02-2004, 03:10 PM
This idea is very fine. I think I will definitelly use this to achieve my goal.
Obviously I can't do that on a lathe, But the idea can be used also on a mill
Thank you very much.
Pigi
Old 07-03-2004, 02:21 PM
RotarySMP's Avatar
Even easier on a Mill. Hex bar is a pretty useful jig.
Regards,
Mark
www.wrathall.com
how to mill angles? cowanrg General Metalwork Discussion 19 05-14-2007 10:35 AM
Any options for an old mill? bjorn General CNC (Mill and Lathe) Control Software (NC) 1 03-04-2005 11:55 AM
Pictures of My Lathe & CNC MILL studysession General Metal Working Machines 14 01-04-2005 05:07 PM
PICS - BOAT HULL CUT WITH CNC ninewgt DIY-CNC Router Table Machines 16 08-02-2004 07:21 PM
Cutting bit questions CNCadmin General Metal Working Machines 11 02-20-2004 04:12 PM
