Old 12-20-2007, 02:51 AM
Smackre is on a distinguished road
Coolant problem
Say you have 120 gallons of coolant. Oil coolant. That is raising 16 degrees per hour. But you wanted it to stay below 70 degree's always. How would you go about keeping it cool. From my calulations you need some place around 14000BTU to cool the oil off.
I have been looking into afew options.
One is pipeing it into the ground into geothermal lines to cool it off.
Another is to pipe it outside and run a big fan on it. A radiator type of design.
Another would be refrigeration cooling. But that is very $$. But a option.
A third would be buy a used machine like this.
http://www.hgrindustrialsurplus.com/...entPageIndex=1
Now I talked to the manufacture of that thing I just linked. They said it was a 23000 BTU unit. Now I also talked to a heating and cooling guy and he said he dont think there is no way its 23000BTU. He though it was more like 2400BTU max.
So how would you guys go about cooling this oil. We are looking into a solution that is long term but economical.
Old 12-20-2007, 03:28 AM
timlkallam is on a distinguished road
14000 btu is just over a ton of cooling not much .I would try this just to see if it would work get a used 2 ton (24000 btu) window air conditioner. Take the cooling coil out of it. Extend the suction line and liquid line . Recharge it .And drop the cooling coil in the coolant. You would have to get someone that does refregeration, it shoud not cost
much.
If that works I would go to a moible home supply store and get a 2 ton ac split system that comes pre charged with freon put the condenser out side the cooling coil in the tank.It would cost around $1500.
Tim
Old 12-20-2007, 08:47 AM
Do you think there would be a issue with condensation. I cant get water in the oil. And if condensation gets into the oil it pretty much ruins it.
Old 12-20-2007, 10:15 AM
Delw is on a distinguished road
What I did on one of my mills was run the coolant lines through a hydraulic radiator and had 2 fans blowing threw it. It already had shrouding and 1/2 or 5/8s lines ( cant remember which ones)
for production jobs it kept the oil cool.
the machine held 50 gals of oil and got hot very quickly. the radiator works pretty darn good.
I also used this same type of set-up but a smaller one for a lathe we ran oil on. that we ran 304 stainless threw a barfeed with fast cycle times and heavy cutting along with deep hole drilling.
Old 12-20-2007, 02:23 PM
how hot was your oil getting? I am running a centifuse cleaning machine on my oil. And it has 2 4hp pumps and large centifuse tanks that heat the oil up. I ran the oil 6 hours today and it went from 70 Degree to 116 Degrees. It seems to max out around 116 Degree so I need to cool it off 46 Degree's.
Old 12-20-2007, 06:51 PM
ConKbot of Doom is on a distinguished road
as long as the evaporator is completely under the oil, and you have insulated lines running to and from the tank, it should be good... however then you have oil leeching/wicking back up whatever insulation you have on it.
Old 12-20-2007, 11:25 PM
It was very hot to the touch. parts were hot when they came off.
I don't know the temps but consideirng we ran them in a swamp cooled shop and at night when we left the shop usually got to be around 90+(az) since we shut all but one cooler off. so the oil was 90 easy when we started up in the morning than 12hours of running gets it pretty warm too.
before we had to set the piece's in inspection for a few hours too cool off to check, after the radiator idea they were semi cool going into inspection.
with the fans running on them hydraulic radiator you would notice a considerable difference.
might not work in your application but use this info for some other ideas. Like maybe a big radiator and run a swampcooler through through it to cool the oil off faster. ( they make little ones that have some serious cooling power)
It beats buying a chiller system for your coolant tanks. I know machine shops that have them and they are expensive
Old 12-21-2007, 11:28 AM
It depends on your shops heating and/or cooling needs, but many shops recover the heat as needed and vent it outdoors when not needed. Works for air compressor and hydraulic systems as well. Just a thought.
Dick Z
DZASTR
Old 12-22-2007, 11:27 AM
NC Cams is on a distinguished road
The lowly aoto ratiation does a FINE job of dissipating heat. I know of a guy who used a bunch of radiators and fans and cooled his quench tanks for a production induction heating/heat treating process. He dumped the heat outside in the summer and recovered it in the winter.
If you contact some radiator suppliers you might find someone who can give you the heat transfer data you need to calculate what you're trying to do. More than likely, however, you're going to hunt and peck. The point is, a typical auto radiator will transfer HUGE amounts of heat and do so quite effectively and efficiently - they do it without even thinking in a car and those have a high underhood thermal density.
Yes, you can also use geo thermal. Ford used the "wading pools" at corporate for their dynos for years and may still do for all I know. Just make sure you don't cross contaminate. The use of water to water or water to oil heat exchangers take care of that - just don't let them mix/leak or the EPA will burn you BADLY. For that reason alone, i'd go oil/water to air heat exchange simply because of the pachaging issues.
THe one isssue with radiaorts that is a PITA can be pumping and circulation - especially purging of air. Once you get solid coolant flowing, things work pretty well and predictabley.
Old 12-22-2007, 04:24 PM
Say you have 120 gallons of coolant. Oil coolant. That is raising 16 degrees per hour. But you wanted it to stay below 70 degree's always. How would you go about keeping it cool. From my calulations you need some place around 14000BTU to cool the oil off.....
I think you will find that you have to go for some form of refrigerated chiller; if you want to stay below 70 degrees you need either air or water several degrees below this. Using something like an automobile radiator would need air at around 55 degrees maximum to get the oil below 70. Using a liquid to liquid counter current heat exchanger you may get away with a difference of only 5 degrees lower but it depends on how much area there is in the heat exchanger and the flow of the cooling liquid.
How cold is the water supply in your area? The simplest solution would be a water cooled heat exchanger just using the water supply if it is cold enough and you are not paying much for the water. However, this is not likely to work in the summer.
Old 12-24-2007, 04:46 PM
*Registered*
Teyber is on a distinguished road
http://forums.extremeoverclocking.co...d.php?t=101902
Linked is a computer overclocking forum. I am not going into details, but you can follow that similar method and run the coolant through it... not sure how many btu's you would need, but you could tune for capacity instead of low temps. Add a txv or cpev and i think that you could manage to keep that thing far below ambient for relativly cheap
Hope this made sense. Just a cool idea.
Regards
  #12   Ban this user!
Old 12-25-2007, 11:21 AM
Just for grins, you might want to google "heat pipe". I was just there looking for an idea to cool the oil in a 60:1 gear reducer. Relatively inexpensive & no moving parts. Have to dump the heat with some sort of heat sink etc. (preheater for water heater?)
Merry Christmas,
Dick Z
DZASTR
Coolant foaming problem Larry Myers Sharp CNC 23 07-20-2010 11:59 AM
Coolant...Which and why? ajl6549 General Metalwork Discussion 15 12-08-2008 09:02 AM
Haas programmable coolant unit problem xs-speed Haas Mills 6 01-30-2008 12:54 PM
Coolant or No Coolant when turning.... Crashmaster General Metalwork Discussion 3 05-20-2007 02:20 AM
Sour Smelly Coolant Problem widgitmaster General Metalwork Discussion 11 08-09-2006 01:40 PM
