Old 12-16-2007, 02:32 PM
Smrtman5 is on a distinguished road
Magnetic Chuck Doesnt Hold
From ebay, i bought a OS Walker magnetic chuck for my surface grinder, and i thought i got a good deal, however it lacks the proper holding power.
Is there anything I can do to make it regain its strength?
Also, what is the proper procedure for installing a new chuck on a surface grinder?
Old 12-18-2007, 08:56 PM
Mcgyver is on a distinguished road
how I've done it is clean everything, make sure the mating surfaces are getting full contact. indicate the fence (if it has one) or side to perfection using a tenths indicator. bolt it down but don't over tighten. indicate fence again. then spark out on a light cut to the top of the chuck.
who did you buy it from? if you bought it used, some idjit may have taken it apart; that's one way to demagnetize it. maybe OS Walker has a rebuild service, have you tried them?
Old 12-20-2007, 12:15 PM
How to i hold the indicator and to what should i square the fence to?
why doesnt my sig picture show up? KOS Forum Questions or Problems 10 10-28-2007 10:04 PM
Magnetic Chuck for Milling Machine...? tdfsu General Metal Working Machines 8 03-19-2007 03:41 PM
Brown & Sharpe Permanent Magnetic Chuck. 5" X 10". dertsap Metal Working Tooling 1 10-13-2006 08:26 AM
mach2 doesnt like my fixture changes? JFettig Mach Software (ArtSoft software) 7 05-20-2005 11:02 AM
how to hold a spline in chuck scott m General Metalwork Discussion 6 12-09-2004 08:18 PM
