Old 12-15-2007, 07:08 AM
mikemill is on a distinguished road
Lathe Tool Turret
Having retro fitted an old Deford Orac lathe I would like to complete the project with a tool turret/changer. Denford made such items, but from looking at some blogs they are difficult to control via Mach.
It then occerred to me that a tool turret is the same as a rotary table, so I am thinking of using a small 4" rotary table powerd by stepper motor set in vertical position on the cross slide, so both centre's match. Then fitting an adapter plate to take turning tools and chucks for centre dills etc, and easly controled as third axsis.
Has anyone been down this route, or has any experiance with turrets on small lathes? or can offer some advice
Mike
Old 12-15-2007, 07:14 AM
RotarySMP's Avatar
RotarySMP is on a distinguished road
A rotary table typically has backlash. You need some way to lock and unlock the table. If you can sort out locking and unlocking, then you can easily sort out the indexing.
Regards,
Mark
www.wrathall.com
Old 12-15-2007, 10:57 AM
Belding's Avatar
Belding is on a distinguished road
Lathe turrets typically use hirth couplings to index and lock the tool in position. They are basically two interlocking face gears. There is a lot of torque on a turret when a tool is in a heavy cut. You have to have something that will be able to withstand this torque and not move at all. If you can find a rotary table with a hirth coupling, it might work.
Converting my Engine Lathe to an 8-Station Turret Lathe! widgitmaster General Metal Working Machines 93 10-31-2011 04:27 AM
Tool holders for Daewoo lathe turret? Chuck Reamer CNC Tooling 1 01-01-2008 07:14 AM
Dorian JUNKDEX tool turret Farmers Machine Milltronics 5 10-18-2007 03:41 PM
Reversing turret tool position motter71 G-Code Programing 5 09-25-2007 09:57 PM
Tool Turret Index Failure hatchmar Machine Problems, Solutions , Wireless DNC, serial port 6 06-09-2005 07:36 PM
