Old 12-11-2007, 05:47 PM
CyberLung is on a distinguished road
SL-30 spindle bearing
I break the main spindle bearing on a hass sl30 lathe, haas want to sell me the hole unit in stead of just 2 bearing, did someone know the bearig model ?
I'm shure that this is a standard bearing...
Old 12-11-2007, 08:59 PM
NC Cams is on a distinguished road
This may or may not be the case - bearing replacement MAY requre special procdures and/or there may be special tolerances and/or bearing fits involved - as in regrind spindle assembly or ID AFTER reassembly. Some spindles are done this way at build and you can NOT simply 'replace bearings'.
THis is why an in-field replacement of "only the bearing" may not be viable. In some cases, it may be cheaper to pay more to have a Haas serviced unit than to experiment with learning how to "repair spindles" on your own machine.
Pay the bill - all in all, it will probably cost you less to do it this way than to do it yourself.
preload on spindle bearing adryan General Metal Working Machines 7 06-21-2010 06:59 PM
Dover Air Bearing Spindle Scra99tch Vertical Mill, Lathe Project Log 4 06-23-2009 08:40 PM
spindle bearing? ged Mechanical Calculations/Engineering Design 4 08-19-2007 09:22 PM
X2 spindle bearing upgrade cncuser1 Benchtop Machines 9 01-04-2007 07:22 PM
Air Bearing Spindle KBW DIY-CNC Router Table Machines 0 11-11-2003 09:44 AM
