Old 12-11-2007, 02:44 PM
Driftwood is on a distinguished road
Question Anyone ever had palette misalignment problems?
I've got a 1985 Hitachi Seiki HC500 horizontal mill that we got a little while ago and it looks like the palette is misaligned by about 0.35 deg. The problem is, the palette is indexable at 1 deg increments.
Its not a big problem, other than that when the palette changes (2 palette machine) its a little rough and bangs a little. But I could probably work around this problem since its always consistent.
We tried to get at it the other day, but it looks like a lot of work and disassembly just to open it up and have a look at whats in there, let alone fix it.
Anyone out there dealt with a similar problem on this or any other machine?
Thanks in advance...
Old 12-11-2007, 03:37 PM
Mitsui Seiki's Avatar
Mitsui Seiki is on a distinguished road
Is the pallet changer misaligned or is the pallet misaligned on the table after clamping?
Stefan Vendin
Old 12-11-2007, 03:58 PM
Its the palette on the table. So, as far as I can tell, its the table. Both palettes sit the same way, and when measuring the table, it shows the same misalignment.
Old 12-11-2007, 09:09 PM
Sounds like someone crashed hard.I think you better take a look under the palett table.
Stefan Vendin
Arc problems nda22 Mach Lathe 2 07-03-2007 08:19 AM
Write wizard and text misalignment bgolash Mach Wizards, Macros, & Addons 12 04-26-2007 07:22 PM
G2 Arc problems CharlesM479 G-Code Programing 8 03-01-2007 07:48 PM
Tsc problems Rawr77 Haas Mills 5 02-23-2007 12:42 PM
Problems vebers Servo Drives 19 05-03-2006 12:59 AM
