Old 06-24-2004, 04:16 AM
pigifly is on a distinguished road
Talking Tools advice needed for start
Hi all,
mi burthday it's approaching, and the first gift coming is a "minimini" mill.
At last I've decided to start with the proxxon mill-drill (System BFW 40/E), because major budget would have been a problem.
What do I need now are the tools to start working some metal pieces.
Can you give me some advice on a few tool that are necessary to start ?
I know that it heavily depends on what work should be done, and what material should be worked, but I also think that there should be some basically tools.
In any case the idea is to get some tools that could mill steel, so ( if I'm not absolutelly wrong ) I could also mill alluminium.
FYI the mill I've choose can handle tools ( chuck inner diameter ) up to 13mm.
What are your advices for this ?
Thanks in advance
Pigi
P.s. Sorry for my not good english
Old 06-24-2004, 04:17 AM
IJ. IJ. is offline
Gold Member
IJ. is on a distinguished road
A really good Kurt style vice would be my first choice !
Old 06-24-2004, 05:00 AM
Ok. This is on the list ( at least something comparable ).
What about cutting tools ?
Pigi
Old 06-24-2004, 08:51 AM
Gold Member
Ken_Shea is on a distinguished road
Here are some small items that you will need/want at some time: dial caliper, micrometer, edge finder, dead blow rubber hammer, counter sink bits, V-Blocks, mini chucks for very small drills, some cheap paint brushes to swipe the chips away, what you need/want never ends
Ken
Old 06-24-2004, 09:38 AM
Originally posted by Ken_Shea
mini chucks for very small drills...
I suppose I should read this as .... bigger chucks, as the basic chuck for this setup starts from 1,5 mm and end at 6 mm
Thanks .
Any other cutting tool ?
Old 12-10-2009, 03:18 PM
wehrmeyer is on a distinguished road
My list
The most accurate vise you can afford, a Kurt vise is a thing of beauty.
A set of paralells
A Starrett " Last Word " type dial indicator or maybe a coaxial indicator
A set of Chinese made endmills 2 and 4 flute ( cheap)
A ER type collet set and an adaptor to fit your mill these have a large adjusting range and can clamp down to near zero.
A center drill
and here in the USA, a fractional drill index and a number drill index.
Happy Machining
Slight delay but back on track, advice needed Darren_T DIY-CNC Router Table Machines 24 05-14-2012 06:53 PM
Shop air advice needed Swede General Metal Working Machines 26 12-10-2009 02:58 PM
advice needed trubleshtr General Electronics Discussion 32 04-21-2005 08:48 PM
Advice needed for Mill Feed Rate raytor Benchtop Machines 4 03-25-2005 01:11 PM
Advice needed: Buying a CNC vs retrofitting a manual jkeyser14 General Metal Working Machines 0 11-17-2004 12:03 PM
