Old 12-03-2007, 02:08 AM
adbuch is on a distinguished road
Power Assist for Pexto 16ga x 52" sheet metal shear?
I purchased a new Pexto 16 ga. x 52" foot shear a about 5 years ago. Although this shear is rated at 16 ga. capacity, I have been told by a local machine tool dealer that it would require approximately 800 lbs of force on the foot lever to shear a piece of 16 ga. steel that is a full 48" wide. I am considering adding some sort of power assist to reduce the required operator effort. One possibility would be to use air cylinders for power assist. By this I mean the type of air cylinders that operate in the same manner as a porto-power ram. Another approach would be to convert the shear to full hydraulic operation.
Do any of you have any ideas or experience with this type of conversion, or have you seen a power upgrade kit that is commercially available?
Thanks,
David
Name:	pexto shear.jpg‎
Old 12-03-2007, 05:43 AM
apache405's Avatar
apache405 is on a distinguished road
if it only takes 800lbs of force on the foot lever, get 800lbs-(your body weight) in free weights from the sporting goods store. just lash the free weights on to the foot lever and then step on it your self.
a pulley system might be the cheapest way to go though.
going to air or hydraulic cylinders would require a redesign of the tool and a lot of work.
Old 12-03-2007, 06:49 AM
sqatch is on a distinguished road
shear refit
I put a 4 in air ram on my tennsmith it works well at 120 psi. I also chopped the foot board off and closed in the front. This makes the machine a pleasure to use.
Old 12-03-2007, 06:52 AM
malbeen is on a distinguished road
I had a similar problem, I used the pump off a cheap pressure washer to power 2 small hydraulic rams the shear was 16 g rated I put an extra support in the middle of the shear and was cutting 6 mm plate 1ft long. the shears were made of steel not cast iron.
MBB
Old 12-03-2007, 10:56 AM
rmarz is on a distinguished road
David - I have the same Pexto shear (many years old), but when I bought it it had two air cylinders on it with spring returns that were actuated by a foot operated valve. I'm sure this was an addition that someone 'cobbled' together, but it works fine. If you want I could send you some photos later in the week.
Rick Marz
Old 12-03-2007, 11:35 AM
rjohnson is on a distinguished road
I think the two 2 inch air cylinders with a foot switch would be the way to go. double cylinders with a 3 way valve.
If you have employees this wouldn't be OSHA approved, with out some safety devices interfaced.
Old 12-03-2007, 11:41 AM
woops don't forget the flow control valves!
Old 12-03-2007, 09:24 PM
Yes I had to put on a limiter on the exust, after cut through the ram takes off at mach 8.
Old 12-03-2007, 09:54 PM
[I]woops don't forget the flow control valves!
Yes I had to put on a limiter on the exust, after cut through the ram takes off at mach 8. [I]
Flow control valves do not help much with air.
Use an air over hydraulic system.
You want 800 lbs force so if you use two cylinders, one at each end of the foot plate, and your air supply works at 100psi you need cylinders with a bore of 2.5". Each cylinder will give you about 490lbs force so you have more than enough.
But you do not supply air directly to the cylinders, you have a reservoir filled with oil and this is connected to the cylinders through a needle valve to control the flow. The air supply goes to the reservoir through the valve you control.
You only need single acting cylinders because you can rig up a spring return.
The reason for using the air over hydraulic is that when you turn the air on it takes the reservoir up to full pressure very quickly. The pressure is applied to the cylinders through the oil but because there is a flow control valve the rate of movement of the shear can be controlled. And, most importantly, when the cut is almost complete and the required force is getting less, the flow control stops everything banging through with a great rush.
Old 12-04-2007, 06:30 AM
double cylinders for the shear
corcerning the flow controls I would put them on the cylinders so the flow is being controlled on the outlet side, free flowing one direction, as it flows in. and restricting on the port thats exhausting.
with single cylinders you loose that effect. hydraulic would be wonderful and smooth but would sure drive the price up unless you find some great deals, like on Ebay for the required equipment
  #11   Ban this user!
Old 12-04-2007, 06:36 AM
I agree air over hydraulic would be a good way to go. If you can figure out the plumbing / valve setup. I have a globe underground lift that has. air over hydraulic. it works smooth. it has two control valves. one to charge it with air and the other is hydraulic flow control.
  #12   Ban this user!
Old 12-04-2007, 07:14 AM
MicroMill is on a distinguished road
We just send the shop "fat kid" over there to stomp it down. )
Sheet Metal Patterns phatfred8 Solidworks 15 05-21-2009 02:34 PM
big problem sheet metal fsa Mechanical Calculations/Engineering Design 3 11-17-2007 04:51 PM
Bit recommendation for sheet metal adda General Metal Working Machines 0 01-26-2007 01:50 PM
Anyone "punched" or crimped sheet metal together? SRT Mike General Metalwork Discussion 4 11-30-2005 01:43 AM
Thin sheet metal itsme Welding, Brazing, Soldering, Sealing 9 03-01-2005 03:24 PM
