Old 11-26-2007, 02:34 PM
AplusWizard is on a distinguished road
Cutting Gears
Hi all!
We've recently purchased a new mill with about 25HP, 8000rpm spindle speed and full forth axis. We are cutting six tooth helical gears from 6" dia stock, that is turned down to 5.850". I started with 4140 Annealed and using the basic formulas out there I came up with a RPM of 2100 and a feed rate of 17ipm on roughing, based on a SFM of 400 and a 3/4" dia. ball nose carbide end mill and 3/8" dia. depth of cut. Now we have heat treated and stress relieved 4140, so I cut the feed rate down to 70% (12 ipm). Now the chips (if I can call them that) look like clumps wet of hair. At this feed rate the cutting is making a high pitched howling noise. Should I put the feed back to where it was? I am quite a newbie at this and would apperciate any help. Thanks!
Old 11-26-2007, 05:05 PM
Smile
Nevermind,
Through experimentation, and getting good documention of the blank material, I was able to solve the problem. Thanks to everybody that took a look!
Working data:
RPM: 1520
Feedrate: 19 ipm
CUTTING WOOD GEARS ClockMaster WoodWorking 0 11-14-2007 10:49 AM
cutting internal gears mog5858 General Metalwork Discussion 4 09-26-2007 10:57 PM
HELP on Cutting Gears on CNC mill rcjetpilot Benchtop Machines 11 01-16-2006 11:57 PM
who's going to GEARS CerveloRod CNCzone Club House 6 09-20-2005 07:11 PM
