Old 11-21-2007, 06:29 PM
WilliamD is on a distinguished road
Cutting threads on lathe...
I have a Logan lathe model 922. It's about a 11 or 12" swing, and 48" bed. It has all the gears, and the power feed and screw cutting levers all work.
The problem is that it doesn't have a "threading dial." It's apparently something on the side of the lathe carriage that has something to do with cutting threads. Is it absolutely necessary to cut threads? Can I just go forward and reverse for each pass. I don't seem to understand the point of the threading dial. Since I don't have one, is there any way around not having one? I could possibly find one on ebay. Is there another method, or something I can fashion myself? Any help or direction would be greatly appreciated.
Old 11-21-2007, 07:06 PM
HuFlungDung's Avatar
Moderator
A thread dial is visual synchronizing aid, something like a timing mark in functionality. It permits the machinist to disengage the half nuts after the first cut, quickly return the carriage back to the start of the thread using the handwheel, then, by watching the thread dial, when a certain marking aligns with an index, it is safe to quickly engage the half nuts again, and the leadscrew rotation will be in the correct phase relative to the spindle to permit the tool to chase the same groove as your first cutting pass.
You can make do by reversing the spindle, thus sending all the gear train into reverse and backing the carriage back to the beginning of the thread. All you lose is a little time, and perhaps create a bit more wear on the half nuts.
If cutting metric threads with an imperial (inch based lead) leadscrew, it is actually necessary to use the reversal method anyway, since the rotation of the leadscrew relative to the spindle is many, many turns between correct synchronous events.
Once you get into doing a lot of thread cutting, you'll probably want the thread dial. Keep your eyes on ebay
Old 11-21-2007, 07:55 PM
Thanks! That makes a bit more sense. I'll definetly keep an eye out then. I haven't tried cutting threads yet, but I'll soon see if I really need to make the investment or not.
anyone cutting Stub Acme threads? WOLOG General Metalwork Discussion 3 11-18-2010 06:24 PM
Cutting threads with sprectra light jjenks General CNC (Mill and Lathe) Control Software (NC) 1 01-27-2009 08:52 PM
Look at this code for cutting threads jjenks General CNC (Mill and Lathe) Control Software (NC) 0 10-25-2007 12:06 PM
Cutting Ext. Threads w/ Pro-Man Wildfire2 Fremonster PTC Pro/Manufacture 0 07-27-2005 11:50 AM
CNC Lathe Cutting Small Threads jbhill Machine Problems, Solutions , Wireless DNC, serial port 5 02-19-2005 08:53 AM
