Old 11-21-2007, 01:02 PM
KENNETH BROWN is on a distinguished road
CRAZY LATHE IDEA
I RUN A 13 FOOT DRILL PIPE IN A SLANT BED LATHE TAKES 2 GUYS TO RUN THIS JOB. MY COMPANY IS PURCHASING A MORI SEIKI SL-6B LATHE TO RUN THESE ON. I HAVE ISSUES WITH THE MACHINE THEY ARE ON NOW AS JAW STROKE WONT ALLOW ME TO DIRECT CLAMP ON THE PART, I HAVE TO ADD TOOTHED EXTENTIONS.THEY WANT TO PUT 2 SCROLL CHUCKS ON THE NEW MACHINE ONE IN FRONT AND ONE IN BACK. I HAVE NEVER MOUNTED A CHUCK TO THE BACK OF A LATHE AND HAVE NO IDEA HOW THEY PLAN ON DOING THIS.SO MY ? CAN THIS BE DONE AND HAS ANYONE EVER TRIED THIS BEFORE. ANY THOUGHTS OR IDEAS?
Old 11-21-2007, 01:42 PM
mnd mnd is offline
mnd is on a distinguished road
You mean something like this? Or a chuck on the tailstock?
(Large spindle bore and a chuck on the back side of the headstock are normal features of "oilfield lathes")
Old 11-21-2007, 01:52 PM
THATS WHAT THEY WANT THANKS FOR THE PIC . I AM IN ILLINOIS NOT A LOT OF OIL FIELDS AROUND HERE HAD HEARD OF THIS BUT NEVER SEEN .
STILL NOT SURE HOW TO ATTACH TO THE MORI BUT NOW I KNOW IT CAN BE DONE. AGAIN THANKS
Old 11-22-2007, 11:43 AM
Bear is on a distinguished road
thats why the other end is threaded
( for attachments )
Bear
Old 11-22-2007, 12:13 PM
ironDigit is on a distinguished road
impressive find but what the #!%*;> would you want a chuck on the bed of your lathe for ?
mind boggling.
Finally CHIPS you can have as much as you can without the doc. complainting about your cholesterol.
Old 11-22-2007, 06:18 PM
mnd mnd is offline
mind boggling.
Turning threads on pipe.
Thats a 9" spindle bore I believe.
Old 11-22-2007, 06:21 PM
mnd mnd is offline
Here is another lathe, as installed.
Old 11-22-2007, 10:43 PM
g-codeguy is on a distinguished road
Please take off your caps. All capital letters is considered yelling and isn't good etiquette on the web. Plus it seems harder to read when you aren't use to it.
Okay, flame me!
Old 11-23-2007, 10:47 AM
I saw a lathe once upon a time, long, long ago that had such a headstock installed at 1/3 of the bed length. Typical large engine lathe on the right hand side of the headstock and a boring set-up left of headstock. End product was 155mm artillery barrels. Pretty good sized thru hole to swallow that tube.
DZASTR
Old 11-23-2007, 03:27 PM
sorry about cap"s program all dat so that's all i see. okay seem's to me that this is done to engine lathes but iam being asked to but this on a cnc lathe with a exsiting hydrulic chuck there are no threads at the back to attach anything olny the hydrulic housing as far as i can tell
  #11   Ban this user!
Old 11-23-2007, 04:02 PM
I think it will be impossible to mount a chuck on the end of the spindle with the hydraulic chuck still in use. If the hydraulic chuck and the hydraulic cylinder are both removed there will be a flange with a bolt circle on the end of the spindle that a manual chuck could be adapted to.
  #12   Ban this user!
Old 11-23-2007, 04:30 PM
mnd mnd is offline
Even with a chuck on the back of the headstock you're going to need some sort of free standing steady rest(s) outboard to support the pipe.
I'm pretty sure that once you're done retrofitting your SL6B you'll be stuck with an old machine with a limited capacity (6.3" spindle bore?).
(This is what a 6B looks like, minus some sheet metal and the control.)
Crazy idea - Sherline headstock on wood router? Rhodan Benchtop Machines 12 11-05-2007 06:49 AM
Crazy Idea? CNC Sharing in Boston area dswink WoodWorking 4 05-16-2007 02:15 PM
Crazy CNC Idea watzmann CNCzone Club House 8 10-09-2005 11:58 AM
Crazy linear bearing idea! mvaughn Linear and Rotary Motion 26 08-19-2005 08:07 PM
LPT crazy Lu_ca Machine Problems, Solutions , Wireless DNC, serial port 9 04-05-2005 06:17 PM
