Old 11-21-2007, 07:46 AM
bdrmachine is on a distinguished road
Computing Motor Size
I need some help on a lathe conversion that I started. The machine is a 14.5 by 40” manual lathe. I have a ballscrew with a 5mm pitch installed in the cross feed. I currently plan on using a 2:1 timing belt arrangement to couple the motor to the axis. Before I get to involved with this I would like some input as to what size stepper motor I need? I realize this will depend on several factors that I have not enclosed. What I’m looking for would be successes others have had in similar retrofits.
Thank
Brian
Computing Cable Rotation From XYZ Point Data FishGuy876 General CAM Discussion 0 09-17-2007 01:55 PM
Motor size beborracho DIY-CNC Router Table Machines 2 07-10-2007 09:23 AM
motor size? eloid Stepper Motors and Drives 1 03-04-2007 03:40 AM
D&M Computing CNC 9 Lathe Info??? TD1932 General Metal Working Machines 1 10-11-2004 03:16 PM
Motor Size PROBUILDER DIY-CNC Router Table Machines 0 04-07-2004 01:54 AM
